Gauge bulb question? - Defender Source
Old September 2nd, 2010, 12:24 AM
Ronanmd1
Jason
1997 D90 HS2.8
Hey guys - noticed my water temp and fuel gauges were very dim the other day after driving on some washboard. Pulled the dash and found that the green bulb inserts had broken off and were floating in the gauges. One of the previous owners had taped the bulbs to the green inserts - which had given way. Now I have two gauges with the green inserts floating around and can't figure out how to get them out or replace them since they seem bigger than the bulb hole!
Don't really want to replace the gauges as they both work fine. Any way to fix this without trying to take the gauge apart? Do I try to bust up the plastic green insert and pull out the pieces? If so - any suggestions on an alternative bulb that will closely match the rest of the stock gauges?
Bit stumped on this one....
Cheers,
Jason
Old September 2nd, 2010, 07:15 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Remove the gauges and shake out the debris. Then get some green colored leds from Superbright to replace them.
Electrical Question #1: Difference between Bulb Holders Manimal Defender Technical Discussions 4 August 26th, 2010 12:59 AM
110 temp gauge mod ECR website question evilfij Defender Technical Discussions 8 July 27th, 2009 10:01 PM
bulb question.... DonFromWhitby Smaller Projects 3 March 6th, 2009 08:17 PM
Fuel pump and fuel gauge relationship question - troubleshoting... arbik Defender Technical Discussions 1 September 19th, 2006 02:31 PM
Temp Gauge question Etrier Defender Technical Discussions 13 May 26th, 2006 06:18 PM
