gauge and lights panel diagram help please! - Defender Source
Old January 19th, 2014, 11:11 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
I've searched-
I need help with getting the correct lights /grounds/wires etc. back to their correct position in the dash and warnings area after I removed an old aftermarket defunct alarm system. Does anyone have a photo or diagram of the correct connections for all of the gauges and lights on instrument panel please?..
Also, can you just bump the wattage on the gauge lights or is that a no-no and too hot for the plastic of the panel to handle?
Thanks again mighty Board!!
KCD
Old April 13th, 2014, 01:21 PM
Nashville's Avatar
Nashville
Victor Hess
1997 Defender 90 NAS
If you still need the diagrams, email me and I'll send the PDF manuals I've found from LR.
victorlhess@icloud.com
1997 D90 ST NAS #1426
British Racing Green
Old April 13th, 2014, 02:31 PM
Dogpilot's Avatar
Dogpilot
James Wallace
Defender 90 1997 NAS ST
If you want brighter lights, use LEDs, no much heat to worry about. Lots of threads on what replaces what, however this is the info I used to do mine that I dredged off this site. The PN are from Superbright LEDs:
LED Bulb Data
Location Color Part # Source # Off Unit $ Total $ Sylvania Alt
Front Parking Amber 67-A15 superbrightleds.com 2 $4.95 $9.90 5007 67
Front side marker Amber WLED-A6 superbrightleds.com 2 $2.79 $5.58
Rear side marker Red WLED-R6 superbrightleds.com 2 $2.79 $5.58
Tail/brake Red 1157-R24 Wide superbrightleds.com 2 $7.49 $14.98 7528 1157
Front/Rear Signal Amber 1156-A24 Wide superbrightleds.com 4 $7.49 $29.96 7506 1156
Back up (reverse) White 1156-W24 Wide superbrightleds.com 1 $12.99 $12.99 7506 1156
Licence Plate White BA9S-W4-12V superbrightleds.com 2 $2.98 $5.96
3rd Brake Light Red WLED-R6 superbrightleds.com 3 $2.79 $8.37 2825
Interior Light White 4410-NW9? superbrightleds.com 1 $4.74 $4.74 6411
Shifter Illum White WLED-W6? superbrightleds.com 2 $2.79 $5.58
Speedo Illum Green B8.5D-GHP superbrightleds.com 2 $2.59 $5.18
Fuel Illum Green T13-G6 superbrightleds.com 1 $2.99 $2.99
Temp Illum Green T13-G6 superbrightleds.com 1 $2.99 $2.99
Tach Illum Green 74-G superbrightleds.com 1 $1.19 $1.19
Hazzard Illum Green 74-G superbrightleds.com 1 $1.19 $1.19
Hazzard On Red 74-R superbrightleds.com 1 $1.19 $1.19
Heat Switches Green 74-G superbrightleds.com 2 $1.19 $2.38
Warn Lamps White 74-W superbrightleds.com 15 $1.19 $17.85 T5 (74)
Flasher Realy N/A EP26 autolumination.com 1 $19.95 $19.95
ht, lights
Tach dies when lights are on Jas0n Defender Technical Discussions 4 November 26th, 2013 02:08 PM
ANother strange gauge question? ipgregory Defender Technical Discussions 9 April 8th, 2012 10:29 PM
No brake lights, turn signals, temp or fuel gauge. John T Defender Technical Discussions 1 August 3rd, 2010 12:54 PM
dash gauge lights very dim Marc Weinstein Defender Technical Discussions 15 October 17th, 2004 01:49 PM
