Gasket removal..... - Defender Source
Old March 30th, 2016, 01:17 AM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
Gasket removal.....
Hey guys,
How do you guys remove the cooked gasket from the block? I am talking about that gasket between the rear cover of the engine that accepts the bell housing specifically.
I tried soaking with WD40, brake cleaner, parts cleaner... Nothing seems to work!
What do y'all do?
TIA
Old March 30th, 2016, 02:45 AM
A scraper with replaceable blades worked very well for me. It is time consuming.
Old March 30th, 2016, 06:29 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Yup. Use a new blade often.
~ Semper Fidelis ~
Old March 30th, 2016, 07:29 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
For the real tough stuff there's this foam product in a bottle that you apply and let sit, then come back with a fresh blade.
Old March 30th, 2016, 07:35 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Flap disc.
Old March 30th, 2016, 08:36 AM
Contractor's Avatar
Contractor
Will
1969 IIA
Permatex makes a gasket remover.....liberal applications of that and a bunch of new razor blades works for me.
Old March 31st, 2016, 01:22 AM
DailyDrivenDefende
Michael
Originally Posted by down_shift View Post
Flap disc.
You are kidding right?
I tell you that paper hybrid gasket with orange stuff is some tuff stuff to remove.
I have been soaking it with Kroil, it seems to loosen things up. I ordered some aerosol gasket remover from CRC.
Time consuming is an understatement..
Old March 31st, 2016, 06:16 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
The other inferior paper gasket just falls off. Ask me how I know. Use the better gasket.
ID:	146373   Click image for larger version
~ Semper Fidelis ~
Old March 31st, 2016, 08:41 AM
down_shift's Avatar
down_shift
Russell
Who wouldn't want gouged surfaces and a billion partials of grit inside and destroying your engine?
That being said, on iron blocks, have been a fan of roloc bristle discs (green) when necessary. Thinking yellow or white is okay for aluminum, but haven't ventured down that road yet.
gas
4.0 V8 engine parts for sale (starter motor, upper gasket set, lower gasket set) bagocheetohs For Sale - Parts 7 August 11th, 2015 07:12 PM
Cigar Lighter Removal and Rear Wiper Switch Removal isleofbones Defender Technical Discussions 6 April 13th, 2013 08:02 PM
Head Gasket Kit? Quimbola Defender Technical Discussions 9 November 5th, 2004 11:24 PM
replacing intake manfold gasket mattdh Defender Technical Discussions 1 May 27th, 2004 10:00 AM
