Gasket help - Defender Source
Old April 15th, 2013, 01:07 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Gasket help
Trying to track down all the leaks and want to know what the name of this is? There appears to be a leak where this cover joins the block. Engine is a disco 200 tdi.
Old April 15th, 2013, 08:17 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Looks like the crankcase breather on the block. Does it connect to the cyclone breather that is connected to the valve cover?
Old April 15th, 2013, 09:33 PM
FYI may vacuum pump was puking out oil, and that is located just behind where you are showing.
Old April 16th, 2013, 02:06 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Jimmy, do you happen to have the part number for the vacuum pump and/or the gasket for the cover? Not sure if 200 and 300 tdi are the same. I can't seem to locate these parts from typical suppliers...
Old April 16th, 2013, 02:17 PM
Parts catalog here: http://www.landroverweb.com/landrove...rover-manuals/
Page 173 or 189, ERR3605 or ERR2026 or 247555
Is is a crankcase vent from the cam gallery.
Old April 16th, 2013, 10:18 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
Mike,
You don't need the gasket. Just use black RTV and be done with it. It will hold up much better.
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old April 16th, 2013, 10:19 PM
Sorry, I missed that you have a 200 tdi. They look totally different.
------ Follow up post added April 16th, 2013 10:20 PM ------
I would recommend that you get a couple cans of brake cleaner and clean off all of the oil, then begin looking for you leak.
Old April 17th, 2013, 03:23 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Thanks for the link!
gas
water pump gasket kolvedic Defender Technical Discussions 2 September 11th, 2005 08:22 PM
rear differential gasket ?? jstrong98 Defender Technical Discussions 5 May 13th, 2005 08:28 AM
d90 dead 4 hours from home! head gasket? vesparover Defender Technical Discussions 4 August 17th, 2004 04:47 PM
