Gasket Heads -> Compression Ratio - Defender Source
Old December 9th, 2011, 11:31 AM
aaronlam's Avatar
aaronlam
aaron lam
1997 Alpine White D90 SW #2212
I might not be understanding this fully but I need to have my gasket heads rebuilt. Is this the time and way to get my compression ratio lowered so I can use lower octane fuel? Is this a stupid idea?
As always... thanks for the advice.
Old December 9th, 2011, 08:18 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
What motor
Land Rover 110
Old December 9th, 2011, 11:54 PM
aaronlam's Avatar
aaronlam
aaron lam
97 4.0l v8
Old December 10th, 2011, 02:02 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
How "low" do you want to go? I run the lowest you fond at normal gas stations in the US (87?). I have a '96 Disco with same engine you have (Gems 4.0L V8).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 10th, 2011, 08:07 AM
Just use stock gaskets and shit fuel. You might be able to find some buick 215 gaskets at summit that have varying thicknesses.
Old December 10th, 2011, 12:33 PM
aaronlam's Avatar
aaronlam
aaron lam
Ah interesting... I think I read most everyone ran 91 octane or above. Was just trying to open the option of 87 or 89... Nothing below that.
Old December 10th, 2011, 12:59 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
You need to be running premium! Why exactly do you want to run anything less?
Old December 10th, 2011, 01:52 PM
aaronlam's Avatar
aaronlam
aaron lam
Haha. I am fine with that but always thought that higher octane wasnt necessarily better... Just depends on the engine. So if I was adjusting the compression ratio to have the engine not knock at lower octane, that would be fine. Always down to save a few bucks.
But maybe I am totally misunderstanding the equation.
Old December 10th, 2011, 06:13 PM
It will only be an extra 3 dollars per tank, 15 gallon tank and the difference between 87 and 93 is about $0.20. I occasionally cheat with my RR, but not my 90.
Old December 10th, 2011, 08:36 PM
Because you drive it 300 miles a year
gas
water pump gasket kolvedic Defender Technical Discussions 2 September 11th, 2005 08:22 PM
Compression Test Results... need help interpreting them martym Defender Technical Discussions 12 March 3rd, 2005 09:46 PM
Redo heads or not? mlw911 Defender Technical Discussions 14 October 21st, 2004 02:42 PM
d90 dead 4 hours from home! head gasket? vesparover Defender Technical Discussions 4 August 17th, 2004 04:47 PM
