Gas Tank woes - Defender Source
Old January 10th, 2008, 12:40 PM
bjf's Avatar
bjf
barry f
94 ST #395
Gas Tank woes
So I bought all the check valves, a fuel pump and slickrock skid plate for my truck only to find out I have a crack in the actual tank where a check valve sits. Has anyone had this problem? Also on the original skid plate the sway bar bolts are welded on. When putting the slick rock one on, how did everyone do it? How do you hold the bolts on top with the tank in to install? What type of bolts did you use?
Old January 10th, 2008, 08:41 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
You might try epoxy on the tank. As for the welded bolts, Mine were not. I would be suprised that they truly are.
Old January 11th, 2008, 12:11 AM
Oxcart13's Avatar
Oxcart13
Mark M
D110
My bolts were not welded. I bet you are just experiencing rust. Hope you ran the tank down - much easier with little gas in the tank. Mark
Old January 11th, 2008, 01:14 AM
bjf's Avatar
bjf
barry f
94 ST #395
Maybe it was just rust and beyond stuck. Thought about epoxy but not so sure I want to mess with it. I hate the idea of fixing it, putting all new seals in, new pump and a new skid plate only to have it leak the same way again and have to pull it all apart. I know similar year range rovers and discoveries had a recall for cracks in the plastic tank like the one I have but because there are so few defenders in comparison they will never do the recall.
Old January 11th, 2008, 07:30 AM
Andrew Vick
Andrew Vick
95 D90
Before the recall on Discovery tanks, we patched quite a few of them and never had a problem. I'd try it.
gas, gas tank
Condensation in gas tank Antonios Defender Technical Discussions 25 March 25th, 2006 09:38 PM
WTB: NAS 90 rear gas tank headdamage Wanted 11 March 8th, 2005 02:46 AM
Group Buy: Gas Tank Skid Plates SlickRockFab The Vendors Loft 53 September 20th, 2004 10:13 PM
