Gas quantity question - Defender Source
Old December 18th, 2014, 04:01 PM
Rover110
Steve
1993 Defender 110 NAS #472
So my 110 is supposed to have a 20.4 gallon tank.
I can run it out of gas and it takes 16 gallons at the pump.
If I go to 220 miles and the light is long on it takes 16 gallons.
Where is the missing 4.4 gallons? I would like to be getting more mileage per tank.
Anyone have any incite?
Cheers
Old December 18th, 2014, 04:07 PM
I'm not sure on the 16 gallons thing, but beware that consistently running your tank low will put additional stress on your fuel pump.
Old December 18th, 2014, 04:09 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
When you say run out of gas, what do you mean? Also running a tank low all the time is not good for the truck.
Old December 18th, 2014, 04:17 PM
maybe your pickup tube in the tank is bent or out of position.
Mark Kellgren
KM4BOR
Old December 18th, 2014, 04:21 PM
gchinsr's Avatar
gchinsr
Greg Chin Sr
1996 Discovery 5 Speed
Might be the wrong pick up for the tank. I would take it out, and replace it. Fuel pump are cooled by the flow of fuel, lack of will kill the pump as mentioned before.
Greg
Old December 18th, 2014, 06:44 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
If it were mine, I would run it out of gas and then drop the tank.
You will be able to gauge by the weight of the tank how much fuel is left inside, once you remove the sender and then check the pickup you'll be able to gauge what is happening to understand why you're only using part of the tank volume.
Then you'll be able to fix it proper like.
RDavisinVA
Rover110
Steve
Tom, I dont run it low as a rule. But I have run out of gas and have an idea at what mileage to pull in. But it always seem to need the same amount whether I run out or get close.
Thanks all I will check your suggestions tomorrow.
Is the pickup tube part of the pump assembly? I have had to replace pump 3 times in 4 years which seems odd to me.
Old December 18th, 2014, 07:08 PM
SonnyAK's Avatar
SonnyAK
Sonny
1993 NAS 110
Yeah, there's definitely an issue there. We definitely get more fuel in the tank when it runs low on longer trips and have never run it out of gas, so it sounds like there's a mismatch of some pick-up parts there. That's probably why it's eating the pumps! Is it still the original tank?
Old December 18th, 2014, 09:19 PM
Rover110
Steve
Original tank but not pump. How many miles do you get to the tank?
Old December 21st, 2014, 09:37 PM
SonnyAK's Avatar
SonnyAK
Sonny
1993 NAS 110
We usually average 15-16mpg with mosly highway driving...so we'd have about 240 miles on a typical run with burning about 16 gal and having 4 left. I guess with that math we'd get a little over 300 miles before empty. Did you have any luck figuring out the issue?
Old December 21st, 2014, 09:43 PM
Rover110
Steve
I'm out of town for the holidays. Will look into it when I get back home. I'm lucky to get 220 before running out. I usually pull in at 210. Hate pushing that thing.
Old December 22nd, 2014, 10:43 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Weighting the tank might be a pain, if it's a 110 there's a drain plug. Just undo the bolt and put a pan so you can measure the rest of gas. No need to undo the tank itself. Dunno if there's such a thing on a 90 but my guess is probably !
Old December 22nd, 2014, 01:20 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
210 miles, that about as far as a NAS D90 will go to on a full tank.
Old December 22nd, 2014, 01:22 PM
BRAB
Brandon
200TDI in a RHD 1986 D90
My Row 90 with under seat tank has a drain plug
Old December 22nd, 2014, 02:18 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
I don't dare risk going over 175 miles without adding fuel...it's a good thing cause I'm old and tend to need more potty breaks...
Old December 22nd, 2014, 06:07 PM
Are the NAS tanks different than RWO 110s? Normal 110s have the same tank as a RRC. 18 imperial gallons which is 21.6 US gallons. Does it have a drain like the "normal" ones (as mentioned above). If so, drain it right out and then measure as you fill.
I can get an easy 650 miles out of my 90. I have around 29 gallons capacity.
Old December 22nd, 2014, 06:14 PM
jafir's Avatar
jafir
Jafir Elkurd
Do you have a side tank and a rear tank?
Old December 22nd, 2014, 06:15 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
The NAS tanks only hold maybe, 16 gallons. It is located between the frame & behind the rear axle. It's plastic & protected by a removable steel skid plate which actually supports the tank.
Old December 22nd, 2014, 06:18 PM
That is the location of all 110 tanks. I wonder why they would have put in a smaller tank. The normal one does not take up all of the room
Also the later ones (from TD5?) are plastic and 18 UK gallons as well.
Old December 22nd, 2014, 06:33 PM
Again US gallon is about 20% smaller (3.8 to 4.54 liters) than the UK gallon.
The smaller tank in the 90 v 110 is simply because the space behind the rear axle is less. Compare overhangs and you'll understand.
Hardtop Rear Gas Shocks Replacement Question!!! thehundredth Defender Technical Discussions 6 November 7th, 2013 06:29 PM
Gas Tank Skid plate install on a D90 - question... pmd Defender Technical Discussions 17 December 19th, 2011 04:04 PM
BF Goodrich KM vs KM2 price/quantity? tebby Defender Technical Discussions 17 October 12th, 2009 01:39 AM
Gas Storage--Gone Bad? When will gas go bad in a Jerry Can? pcscharfe Misc. Chit-Chat 7 August 29th, 2007 05:42 PM
ZF Transmission Refill Quantity 48vphantom Defender Technical Discussions 1 February 14th, 2005 12:53 AM
