Gas quantity question - Page 2 - Defender Source
Old December 22nd, 2014, 06:40 PM
I understand all of that. What exactly are you thinking I do not understand? This thread is about 110s. Normal 110s have 18 UK gallon tanks which is 21.6 US gallons. Viton said NAS 110s have 16 US gallon tanks which seems strange.
Old December 22nd, 2014, 06:41 PM
Originally Posted by jafir View Post
Do you have a side tank and a rear tank?
Yes.
Old December 22nd, 2014, 06:55 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Sorry for the confusion as I was speaking of NAS D90's since someone had brought them into this discussion. I have no idea of the fuel volume of a NAS 110.
Old December 22nd, 2014, 07:16 PM
The tank on my NAS 110 is about 20 gallons US, is made of steel and has a drain plug on it.
Mark Kellgren
KM4BOR
Old December 23rd, 2014, 02:15 AM
SonnyAK's Avatar
SonnyAK
Sonny
1993 NAS 110
That's right - 20.4 per the NAS 110 specs. I think the OP does have some issue with his fuel system since he hasn't been able to get anything close to that into his when running it empty...definitely seems like a pick-up issue or something similar...or a smaller tank installed later...
Old December 23rd, 2014, 08:30 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by rdavisinva View Post
If it were mine, I would run it out of gas and then drop the tank.
You will be able to gauge by the weight of the tank how much fuel is left inside, once you remove the sender and then check the pickup you'll be able to gauge what is happening to understand why you're only using part of the tank volume.
Then you'll be able to fix it proper like.
OK then...
RDavisinVA
Hardtop Rear Gas Shocks Replacement Question!!! thehundredth Defender Technical Discussions 6 November 7th, 2013 06:29 PM
Gas Tank Skid plate install on a D90 - question... pmd Defender Technical Discussions 17 December 19th, 2011 04:04 PM
BF Goodrich KM vs KM2 price/quantity? tebby Defender Technical Discussions 17 October 12th, 2009 01:39 AM
Gas Storage--Gone Bad? When will gas go bad in a Jerry Can? pcscharfe Misc. Chit-Chat 7 August 29th, 2007 05:42 PM
ZF Transmission Refill Quantity 48vphantom Defender Technical Discussions 1 February 14th, 2005 12:53 AM
