gas guage bouncing around - Defender Source
Old April 16th, 2012, 01:13 PM
CDeWan
Clay DeWan
5.3L beastie
Gas guage started bouncing around last week for no reason. I didn't hit it around or call it names.
I am hoping it is the guage on not some mysterious ground. Anyone else have this problem and found out it was the guage or did you end up having a bad sending unit in the tank?
Thank you in advance,
Clay
Old April 16th, 2012, 01:55 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
i am shocked you just noticed now. 90% of them do. =)
Old April 16th, 2012, 02:00 PM
CDeWan
Clay DeWan
5.3L beastie
Keith,
Do you mean bounce around or go bad? Mine has never bounced around before in the 6 years I have owned it. All other guages are still acting fine, just the gas guage is going bananas.
Old April 16th, 2012, 02:27 PM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
I have never seen one that didn't bounce around.
Old April 16th, 2012, 02:38 PM
Are you sitting still at a light, or weaving through traffic when it happens? Mine jumps off a cliff when I turn left around a corner.
Old April 16th, 2012, 03:23 PM
CDeWan
Clay DeWan
5.3L beastie
Thanks guys. Yep should clarify. Normally up to last week the guage would drift with turns as the fuel sloshes from side to side, no more than expected.
But last week it now will bounce around from empty to half a tank, going back in forth in the meantime, inconsistent with any movement in the vehicle.
I could see it being a faulty ground issue if it followed some pattern or just went dead altogether as the sender is activated by negative (ground) resistance. but doesn't quite seem to follow the pattern and I can's see the float sinking the unsinking for no apparent reason unless it is a magic float ball.
Old April 16th, 2012, 05:32 PM
Spook's Avatar
Spook
Rich
97 Defender 90
Mine has always bounced too. I ordered a new VDO guage online for $30 shipped. have not put it in yet.
Old April 17th, 2012, 05:03 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
bouncing. most gas gauges bounce. i think 97s tend to bounce more - not sure why though. very rarely do they go bad.
Old April 18th, 2012, 12:21 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Mine bounces so much it only works when it wants to.
Jimmy Buffett
gas
Temp guage problem TDI Guy Defender Technical Discussions 24 June 28th, 2013 10:42 PM
Gas Boycott, interesting read draaronr Misc. Chit-Chat 7 April 7th, 2005 11:43 AM
Need replacement locking gas cap vnrover Defender Technical Discussions 17 April 10th, 2004 04:29 PM
