Gas gauge always reads empty - Defender Source
Old September 2nd, 2013, 11:45 PM
sro
Sam Odio
2008 LR2
Pulled the gauge off the dash. The fuel sender is reading 0 ohm when the vehicle off and infinite resistance when it's on.
I'm assuming the next step is to drop the fuel tank and inspect the sender. Is there anything else I can check before I do that?
Unrelated: I tried siphoning the gas tank to empty it but I can't seem to get the hose to the bottom of the tank (it seemed to be blocked somewhere in the filler neck). Has anyone had this problem before?
Old September 3rd, 2013, 12:40 AM
kellykortman
kelly kortman
1994 land rover defender
I had a fuel gauge that always read "full" and it turned out to be an electrical issue in the dash that also was sending me wrong readings on the engine temp. but in owning a defender it could be anything to include a bad fuel sender as you've said, personally I've had rewiring done, new fuel lines, fuel pump, fuel filter, etc. If your rig is still running then you are better off than I was when I was dealing with my issues.
gas
D-90 gas gauge alaskajgg Wanted 0 April 6th, 2005 12:31 AM
Gas Gauge fried alaskajgg Defender Technical Discussions 0 April 4th, 2005 11:38 AM
Gas Gauge Zimbo76 Defender Technical Discussions 7 May 13th, 2004 09:55 AM
Gas Gauge Possessed proulx70 Defender Technical Discussions 1 February 18th, 2004 02:20 PM
