Gas Gauge - Defender Source
Old May 12th, 2004, 08:57 AM
Zimbo76
Keith Page
1994 Defender
Gas Gauge
Hey all,
I am having a problem with my gas gauge. It is working fine, or so it seems untill I get into the last 1/3 of the tank. The the needle swings wildy, especially when I am going around corners.
I am guessing it is lose in there, and kinda floating around.
Any suggestions?
I am also going home to South Africa soon, and will be looking to bring some stuff back for my D90. I am going to get some prices and part lists, to see if anyone else wants in. Would anyone be interested in going in on a container of parts?
Some of the stuff in South Africa is very cheap.
I got a really nice recovery kit for around $80. Similar sells for $250 here. There are many other parts too, so I will keep you posted.
Old May 12th, 2004, 10:21 AM
jstrong98's Avatar
jstrong98
Jon Strong
I'm interested in some discount parts etc.
Be careful with the recovery items, make sure that they are ANSI spec or certified.
JS
Old May 12th, 2004, 10:32 AM
My gas guage does the same thing. I don't know of any fix....
Old May 12th, 2004, 10:34 AM
Art Vigil's Avatar
Art Vigil
Arthur Vigil
Keith, your gauge is working. Both of my D90's did the same thing. I can say that the gauge in my '95 worked better than the '97 I have now. It was more accurate and easier to read.
Arthur M Vigil
Colorado Native
Former owner of:
'95 RRC - 3.9V8 Rimmer Supercharged!
'72 Series III 88" NADA Turner 2.25 petrol (Lovely Rita)
'95 RRC Brooklands/TWR Edition 3.9V8
'97 D90SW NAS #2426 - 3.9V8 Rimmer Supercharged!
'95 D90ST NAS#2620 - Original owner
Old May 12th, 2004, 12:05 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
I think it is just a common thing. You just have to be careful when i gets close or touching the red/orange. Mine will cut out on me.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old May 12th, 2004, 12:10 PM
Zimbo76
Keith Page
1994 Defender
I keep track of my gas, but it certainly bothers me, when it swings below the red on a right turn.
I don't mind so much the running out of gas, but I do mind the $80 it costs for Landrover to reset the "CHECK ENGINE" light when the O2 sensor thinks you ran out of gas.
Old May 12th, 2004, 12:15 PM
Keith, my gauge does the same thing, I just check it when I'm stopped and I fill up when ever the trip odometer reads over 150 miles, then I reset it when I fill up, it's kinda a pain but what else can you do?
Old May 13th, 2004, 09:55 AM
souza's Avatar
souza
Dave Souza
1995 Defender 90 SW #275
Quoted from the FAQ (and it has worked for me several times):
"The Check Engine light can be reset (assuming you have fixed the problem that caused it to illuminate in the first place) by disconnecting the lead from the display unit while the ignition is switched on. There is a 5 pin (or so) connector in the lead from the display. Then switch the ignition off and wait for the main relay to drop out. Recoonect the lead and evrytjing should be fine. Of course this didn't work for me either so what I did was disconnect the battery for about 30 seconds while the lead was disconnected and that fixed it."
I have reset my check engine light serveral times when I was having 02 sensor problems using both the display lead method as well as disconnecting the battery. The display box will also show you the code being thrown (which is how I knew it was the 02 sensor!). It's under the passenger seat, for those who don't know....
Originally Posted by Mike Hippert
I could run circles around Dave Souzas 90
gas
94-95 gas gauge mattdh Wanted 5 January 29th, 2007 05:23 PM
D-90 gas gauge alaskajgg Wanted 0 April 6th, 2005 12:31 AM
Gas Gauge fried alaskajgg Defender Technical Discussions 0 April 4th, 2005 11:38 AM
Gas Gauge Possessed proulx70 Defender Technical Discussions 1 February 18th, 2004 02:20 PM
