Gas Cap leak - Defender Source
Old April 19th, 2005, 09:42 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Gas Cap leak
Anyone ever have this happen before? I've changed caps and my tank is still pushing gas. I wonder if I've got a line blocked somewhere -- recommendations?
Thanks in advance,
Doug W.
Old April 20th, 2005, 02:17 AM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
so this is a new cap sence RRV?
Insert pithy quote here.
Old April 20th, 2005, 10:22 AM
Doug's Avatar
Doug
Doug Walker
Unhuh. It was leaking before and after RRV. stock cap started leaking, aftermarket cap started leaking, replacement stock cap leaks.
Doug W.
Old April 21st, 2005, 11:19 AM
Doug's Avatar
Doug
Doug Walker
Bump, anyone have a suggestion?
Old April 21st, 2005, 11:51 AM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
Just so I'm on the same page as you.... is the problem that your system won't pressurize completely?
Have you put your gas caps on a tester to make sure they're bad?
Old April 21st, 2005, 12:29 PM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
Doug,
are you running the right part? Stant: BG791 or NAPA 70321103.
I also have an extra cap that I know does not leak... On my truck that is. would you like to try it out and see if it corects the problem. That way if it doesn't we could move on to other causes.
Old April 21st, 2005, 02:32 PM
Doug's Avatar
Doug
Doug Walker
I have a Disco cap on their now, 'cause I wanted to upgrade to the cap with a 'tail' so it can't get misplaced. It's brand new. John Lee from EE did the same with his Defender and it worked great, no leak or issues at all. I believe that somehow my gas tank is getting OVER pressurized, and pushing gas slosh up the fill pipe with such pressure that hte cap is releasing and letting it out. So I'm wondering if there is a simple release valve or vent that is stuck or clogged.
DW
Old April 22nd, 2005, 01:03 PM
Rod Hayward
Rod Hayward
95 D90 Green #2288
This spring I got rid of a medium duty deisel truck that had compression problems in the top end. It created so much pressure it pushed back up the fuel system all the way to the two 50 gal tanks, which bulged out like ballpark franks.
A good guess in your situation might be a restriction in your return line.
gas, gas cap
Gas cap lock & lug nut locks ini88 Defender Technical Discussions 9 August 4th, 2006 01:32 PM
Tethered gas cap??? Dredd Defender Technical Discussions 6 October 13th, 2005 04:22 PM
Gas Cap!!! Dfndr90 Defender Technical Discussions 14 August 26th, 2004 09:14 AM
Need replacement locking gas cap vnrover Defender Technical Discussions 17 April 10th, 2004 04:29 PM
