Gas cap from Hell - Defender Source
Old September 13th, 2014, 09:42 AM
willr's Avatar
willr
WILL RAGSDALE
NONE
Gas cap from Hell
So, I ordered a new gas cap for my 110 and the cap is on and I cannot get the thing off. Cap is the old three notch style. The cap rotates freely but will not come off. I push cap down and I can feel some spring resistance but the damn thing will not come off. Any suggestions?
Old September 13th, 2014, 09:50 AM
willr's Avatar
willr
WILL RAGSDALE
NONE
Old September 13th, 2014, 10:00 AM
the rover shop
shayne young
Oxy acetylene torch will get it off..... As you turn the cap you should feel the slots click into line if you pull it up at the same time.. Once they line up you may need to just supply a little more pressure..if it went on..it's gotta come off..if I recall there is a second position before it comes off...
Old September 13th, 2014, 10:13 AM
willr's Avatar
willr
WILL RAGSDALE
NONE
Thanks, I am going to get the beeahhhtch off.!!!
Old September 13th, 2014, 10:47 AM
Drill out those rivets!
Hopefully the top of the cap will come off easily.
Old September 13th, 2014, 10:52 AM
Stormer's Avatar
Stormer
JP
2008 RRSC
Where did you order it from?
"These are the best traveled nuts on d-90 . . ." ABrooks
Old September 13th, 2014, 03:23 PM
willr's Avatar
willr
WILL RAGSDALE
NONE
Rovah Farm, Trevor is great to work with. I should have sent him a picture. I was able to get the cap off, wrong part.
Old September 13th, 2014, 03:29 PM
willr's Avatar
willr
WILL RAGSDALE
NONE
Need a cap to fit this tube, three notches on the inside.
ID:	102819   Click image for larger version
Green HELL :: 1972 Land Rover 88" SIII Ren Ching Defender & Series Truck Registry 1 April 3rd, 2013 01:43 PM
what the hell are these for ? Uncle Douglas Defender Technical Discussions 8 April 28th, 2011 02:59 PM
what the hell? TravelerBT Misc. Chit-Chat 21 January 7th, 2010 05:45 PM
H1N1 is hell FlaD90 Defender Technical Discussions 15 November 29th, 2009 11:31 AM
Help! Rear Shock Replacement Hell... hutch Defender Technical Discussions 9 July 4th, 2008 09:51 AM
