Galvanizing Coil Springs - Defender Source
Old May 11th, 2011, 04:50 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Anyone had any issues galvanizing coil springs? From everything I've read it should be fine but I was wondering about any real-world issues that people have run into.
Old May 11th, 2011, 04:56 PM
bjf's Avatar
bjf
barry f
94 ST #395
Why would you bother?
Old May 11th, 2011, 05:13 PM
jaygoss's Avatar
jaygoss
Jay Goss
'60 Series II Station Wagon
I would think it would flake off with all of the flexing.
1960 Series II 88" SW
1994 D90 ST Arles Blue (sold)
1963 SIIa SWB (sold)
1971 SIIa SWB (sold)
2000 Disco SII (sold)
1995 RR Classic SWB TWR edition (sold)
Old May 11th, 2011, 05:18 PM
Has anyone heard of a coil spring rusting to the point where it would make a difference?
mattdh's Avatar
mattdh
Matt Hurst
why wouldn't you bother? if it can be galvanized and you are head to the galvanizer- 4 springs wouldnt cost you any more. after i did all my galvanizing i thought about that the springs and a few other parts that i didnt do. (but im guessing there is a reason why we dont hear more about it)
Old May 11th, 2011, 05:24 PM
ajh
Andrew J. Hutton
I do enough galvanizing every 6 months that adding in some springs is a negligible cost. The rust may be only cosmetic but looks bad when everything else is galvanized and standing up well. A number of spring manufacturers do galvanize them, just none of the ones available for Rovers it seems.
Old May 11th, 2011, 05:46 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
yes, you can, but need to understand the material and the galvanizer needs to know their stuff.
good read: http://www.ingal.com.au/IGSM/14.htm
a good option we have used here for salt water emersion is a PVC coating - a lot like the stuff on tool handles(but not the DIY crap. Doesn't crack like powder coating does do to the spring torsional movement.
http://www.usplasticcoatings.com/pla...s_services.htm
Old May 11th, 2011, 08:58 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
I understand that you can galvanize spring steel but wouldn't the heat from the galvanizing process ruin the temper in the springs that the spring companies charge you hundreds for?
MUDSUX
Old May 11th, 2011, 10:20 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I did some quick checking on the internets and it seems that molten zinc for galvanizing is around 860 degrees and a spring temper is about 600 degrees.
The question is how hot does the material being galvanized need to get to accept the zinc?
I think you might be compromising your temper by galvanizing your springs. Also I think it would flake off because of the compression. But if some manufacturers are doing it I guess it's possible.
Old May 12th, 2011, 12:10 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Yes actually, a little surface rust in spots or even light surface rust across a high percentage of the spring is OK but once you get heavy scale forming the wire effectively gets smaller, and coil springs start to weaken fast. But you'd have to abuse a spring, leave it covered in salt, etc for years before it got weak enough to collapse.
Old May 12th, 2011, 01:10 PM
Of course it is possible. But by the time that happens they will be worn out anyway. And they are cheap and easy to change. Hell, yours come out by themselves
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old May 12th, 2011, 02:48 PM
TS888's Avatar
TS888
Tony Sims
1984 110
The original rear coils on my 300TDi donor 110, which spent most of its life in the Orkney Islands in the North sea, were corroded to hell, and were barely compressed (maybe 1/2") from stock specs. I can't see any reason to galvanize springs.
Tony
1984 110 "Smokey" (sold)
Old May 12th, 2011, 03:28 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
bling...why not chrome them
Old May 12th, 2011, 03:54 PM
Naplm00
Matthew
I blasted a set for an e30 with glass beads, then sprayed them with plasti-dip
It is a rubber like coating that is abrasive resistant and goes on like spray paint, very flexible
Peeps paint entire wheels and car trim with the stuff.
http://www.amazon.com/Plastic-Intl-1...5230051&sr=8-1
did mine in red 3 years later in the NE they look great, except for where it was rubbed off on 2 dead coils touching
coil, galvanizing
WTB Front Coil Springs D90/RRC paydan Wanted 1 March 29th, 2011 04:08 PM
Rear Coil Springs for 110 Santiago Defender Technical Discussions 6 January 17th, 2008 12:28 PM
brake pad anti rattle coil type springs. thewap Defender Technical Discussions 2 August 20th, 2006 09:56 AM
Need Help with Springs for an 88 Coil Truck TDI Guy Defender Technical Discussions 11 June 6th, 2006 06:55 PM
Front shocks outside of coil springs? castlerock4x4 Defender Technical Discussions 19 May 12th, 2004 04:23 PM
