Galvanizing a bulkhead? - Page 2 - Defender Source
Old January 9th, 2013, 10:06 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Tom, I Galvanized my bulkhead with out a problem. You do have to make sure that the tank isn't too hot. The Galvanizers use different temps depending upon the operation and what they are running. If you are going to paint it do not have them dip it in the oil tank after they are done galvanizing it. Otherwise you need to clean it so that you get all of the oil off of it. The main concern on mine was that the material got into the center of the bulkhead. The place I took it to in Ashville, VA took time and did it right. No noticeable warping. I painted mine with out a problem.
I am not a chemical engineer but the material used in galvanizing is a sacrificial metal. The action of rusting will attack the galvanized material before it attacks the metal. Even if everything doesn't get covered the material close to it will react first before the metal. It is similar to a boat that has zink's on the shaft to prevent corrosion.
Land Rover 110
Old January 9th, 2013, 10:23 PM
Galv is best. Paint with epoxy primer like Awl Grip 545. Top coat with two part polyurethane. No more worries.
Pic of galv/painted BH on my series build thread.
Old January 9th, 2013, 11:34 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Slight wave on flat (non visible) areas of my bulkhead and there might just be a 1/8 of movement somewhere cause it takes a little persuasion to get it back on the bolts/frame.
Old January 10th, 2013, 06:31 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
When I did my frame they said the tank was 800+ degrees
Old January 10th, 2013, 08:49 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Tom, how did the galvanizing go? Any pics?
Old January 10th, 2013, 09:27 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Great, I posted a link to a video of it a while back.
Hows yours going
Old January 10th, 2013, 09:34 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Trying to sort out my axles hahaha, but seriously having some difficulty adapting the fronts to RHD
Old January 23rd, 2013, 04:49 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Mordant Solution
I read this is the stuff to use on the bulkhead after Galvy, but it looks like its not sold in the US.
Is it called something else here?
Old January 23rd, 2013, 04:54 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
When getting it dipped just make sure they let it air cool and it will be fine.
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old January 23rd, 2013, 05:21 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Ok, so the scoop is I have tried two Galvanizing places in Houston, 1 replyed not worth their time. Other not sure will get back to you, not yet has he.
There a few others around but want to ask if anybody has had it done in Houston?
anybody know somebody? somebodys bother-in-law maybe?
thanks
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old January 25th, 2013, 06:25 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Should I do the trans tunnel parts?
Anyone tried this?
Lt77 so I assume it's steel
Old January 25th, 2013, 03:25 PM
61rover's Avatar
61rover
John Crouse
Does anyone have a list of all the little plastic plugs, clips, and othe misc little fittings for the NAS D110 bulkhead? Mine is totally stripped down and I'd like to do new when it comes back from Galvy.
Old January 25th, 2013, 03:30 PM
I don't but when I did it I called Les as Roversnorth and he got me everything I needed (which was not everything because I had saved most of the orange ones and a bunch of others I saved too).
I bought like $1000 worth of little stuff (bolts, fixings, LHD dash parts etc.) over the course of a couple month and I used to ring up les and say "it is your least favorite customer" and he would laugh, but he did a great job finding everything and the prices were reasonable (I bought a lot of stuff!) save a few things like the square nuts for the rear crossmember area.
Old January 25th, 2013, 03:34 PM
61rover's Avatar
61rover
John Crouse
Thanks Ron. I'm really focused on the engine facing side. I'm hoping much of the dash side is ok.
Old January 25th, 2013, 03:54 PM
He got me all that stuff too. The clip that hold the zip tie, the brake pipe brackets etc. You will not be able to get all of the inside stuff out in one piece so you will need some of those too.
Old January 25th, 2013, 04:35 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
He's quite right about the challenge of salvaging the small inserts on both sides of the bulkhead. I ran through the parts book and ordered the correct quantity of everything that fits into the bulkhead on both sides. I should have my list somewhere but it is set up for ROW trucks.
Old January 25th, 2013, 05:16 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Off to the Galvanizer in the AM, Should I do the tunnel pieces for the Lt77?
Old January 25th, 2013, 05:24 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
The one that attaches to the bulkhead is steel and I had that one dipped but the one that goes around the gear shifter is aluminum (atleast mine was)
Old January 25th, 2013, 06:38 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
That makes sense, since that's the one that rusted out on my 90.
I just bought the high temp RVT, did you make plugs, or did you put it on the bolts?
Old January 25th, 2013, 07:37 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Tried several diffrent things and posted results here
http://www.defendersource.com/forum/...t=26346&page=4
galvanizing
Galvanizing the bulkhead D90user Series Technical Discussions 16 September 30th, 2010 10:13 AM
Galvanizing the bulkhead? crobinson Defender Technical Discussions 2 December 30th, 2005 01:34 PM
Bulkhead Rust TurkD90 Defender Technical Discussions 4 May 14th, 2005 05:06 AM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
Help with installing bulkhead on chassis Chris Cox Defender Technical Discussions 2 June 5th, 2004 09:33 AM
