Galvanized body capping - Defender Source
Old October 7th, 2007, 10:30 PM
bjf's Avatar
bjf
barry f
94 ST #395
Has anyone changed the rear capping on their defender to be galvanized like on a series vehicle. If so, do you have any pictures? Curious to what it looks like.
Old October 7th, 2007, 11:50 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Lifted from ECR site, I understand that if you but new the holes never line up, so its best to have yours dipped.
--Benjamin Franklin
Old October 8th, 2007, 01:57 AM
bjf's Avatar
bjf
barry f
94 ST #395
mine is blue also. Are there any clearer photos of this truck?
Old July 8th, 2015, 03:14 PM
jperakis
James Perakis
94 ST
can anyone comment on the the work involved to replace the body cappings on a NAS ST?
It's the only place on my truck where I see anything close to rust.
remember two things...
Old July 8th, 2015, 03:35 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
What do you want to know?
Old July 8th, 2015, 03:39 PM
jperakis
James Perakis
94 ST
As I understand the process I'll need to remove the cage (obviously), then drill out some but not all of the existing rivnuts. From there it sounds fairly straightforward to remove the cappings.
I guess my question is, what exactly do I have to drill out?
I would imagine rusting cappings are a fairly common issue especially with the ST 90's... seems strange that there is relatively little information on this topic here and on the internet as a whole.
Old July 8th, 2015, 03:41 PM
Is it just surface or real cancerous rust? If not that bad, then just sand the rust down, primer, mask, and paint accordingly.
Old July 8th, 2015, 03:46 PM
jperakis
James Perakis
94 ST
just surface rust.
What you suggest seems reasonable... considering my tub is line-x'd all the way up to the cappings, maybe I could just top them off.
Thanks for the suggestion.
Old July 8th, 2015, 04:06 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Nothing special, honestly if your going to galvanize your capping just drill out all rivets and rivnuts. They are tricky to remove so just play with them and they will pop off. Then reinstall all new rivets and rivnuts on install.
Old July 8th, 2015, 04:50 PM
Yes. On NAS 110s they are glued on which makes it harder to get off, but I have done it on a few trucks and it is totally doable and highly worth it.
body
Fitting D110 Body Capping mattarm Defender Technical Discussions 9 July 19th, 2010 07:43 PM
What are the body capping options / differences? Hans Defender Technical Discussions 4 August 9th, 2009 12:49 PM
rear 110 body capping WhiteD90 Wanted 10 May 6th, 2008 11:25 AM
Where to find galvanized body cappings? Seanh Defender Technical Discussions 5 March 29th, 2006 04:48 PM
body capping on rear tub WhiteD90 Defender Technical Discussions 5 October 6th, 2004 06:10 PM
