galvanic corrosion - Defender Source
Old September 10th, 2013, 12:18 AM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
galvanic corrosion
There are many previous threads on this forum about galvanic corrosion on doors and other body parts, etc, and how repairs are simply about peeling back the aluminum, welding in new steel channels and putting it all back together. But how reversible is the corrosion on the aluminum skin: the blistering paint, the orange rust that has seeped through the metal apparently and/or the white oxidation residue? If the aluminum skin hasn't rusted through (can it do this?), is it a matter of sanding the nasty stuff away and repainting?
Or, does the old aluminum have to be cut away and new stuff welded back in?
Old September 10th, 2013, 01:04 AM
If you don't have holes, it should not get worse and should be fine with a repaint and isolate the aluminium and steel. At least that is my experience with door bottoms.
Old September 10th, 2013, 06:37 AM
I'll take flak for this, but the aluminum can be repaired with that aluminum solder stuff. It goes by many names, Luma-weld, etc.
You have to grind out the oxidation with a Dremel, then use a MAPP torch to heat the area and melt new metal into the divot. Sand or file smooooothe. Even if it is perforated it will fill gaps up to a quarter inch.
Best approach to prevent galvanic corrosion? ajh Defender Technical Discussions 8 April 7th, 2012 02:06 PM
Corrosion Oxcart13 Defender Technical Discussions 3 September 3rd, 2005 05:22 PM
Corrosion repair ideas mattarm Defender Technical Discussions 6 February 2nd, 2005 10:18 AM
bulkead corrosion near windscreen hinge Neo Defender Technical Discussions 2 March 8th, 2004 01:54 PM
LR Corrosion Warranty Chris Cox Defender Technical Discussions 1 October 5th, 2003 07:41 PM
