Galled rod bolts? - Defender Source
Old July 13th, 2014, 09:50 PM
ezzzzzzz
Mark Garrenton
Galled rod bolts?
I acquired a Disco with a 4.0 that was supposed to have a oil pump failure. I tore down the engine that showed some sign of coolant in the oil upon disassembly. I was happy as the overall condition was very good with no indication of spun bearings, damaged valve train, camshaft/lifters or cylinder wear/liner drop. The main bearings showed signs of scarring from trash in the oil though. I decided I'd get the crank undercut and polished so the tear down began. Here comes the reason for this post. The rod bolts on 4 of the connecting rods galled upon removal. The galling happened in the caps. It didn't matter if the bolts were removed one at a time or slowly backed out a little each until cap could be pulled. Has anyone else experienced this? What was the resolution? I'm heading to a friend's machine shop for evaluation tomorrow hoping they can be salvaged. A f'ing connecting rod is +$150 each aftermarket (+$400 each OEM) for these piece of crap Land Rover/Buick boat anchors.
Old July 13th, 2014, 10:17 PM
Seems like every deal you do with Sparky you get the short end of.
Old July 13th, 2014, 10:25 PM
ezzzzzzz
Mark Garrenton
true that but the price was right even in scrap weight.
bolts
Heavy Duty Track Rod Kit with Tie rod ends $250.00 SafariHP The Vendors Loft 0 August 30th, 2012 04:20 PM
Defender 110 Tie Rod Steering rod change tjfslaughter Defender Technical Discussions 23 December 14th, 2011 10:53 AM
1998 range rover convertible one-of-a-kind 4x4 sut like hot rod street rod Capt Milks The Flea Market 0 December 2nd, 2011 07:06 AM
Equipe Panhard Rod and HD Track Rod Rugbier For Sale - Parts 14 March 23rd, 2011 09:27 PM
Tie Rod/Track Rod joint removal....aarrrrghh DNinety Defender Technical Discussions 5 October 24th, 2010 01:08 PM
