FYI - Oil coller adapter ring - Defender Source
Old January 11th, 2007, 09:49 AM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
Thumbs up FYI - Oil coller adapter ring
In order for me to upgrade my oil lines, I need an oil line adapter ring with the smaller 18mm orifaces for the lines as mine had the larger, although the radiator was correct.
Should someone else run into this issue, the LR part number is ERC 8501. The big O-ring for the adapter where it mates to the engine block is ERR852. I was forced to purchase them new from Rover's North as I was unable to locate one used. The adapter was $161.94 and the O-ring was $3.84.
These are now installed, leak free, and thus verified to be the correct parts. Just thought I would throw this on the board in case someone searches for it later. BTW, ty Mike for the help in locating these parts.
Old January 11th, 2007, 11:32 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
that's great info. i was thinking of doing the exact same thing....$161 sure is a lot of money though
Old January 12th, 2007, 12:08 AM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
I know. Mike at ECR said he comes across them now and again so you might check with him if you can wait. Unfortunately my lines looked pretty rough and I was unwilling to take the chance.
Old January 12th, 2007, 08:05 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
We are also working on a lower cost adapter and trying to convince Russell (Edelbrock) to make a 20mm adaptor. No final word on either though.
Email:
oil cooler adapter ring Gore Ranger Wanted 1 June 16th, 2007 02:57 PM
Oil filter adapter ring ScottYates Wanted 10 December 19th, 2006 08:18 AM
Oil Cooler Adapter O-ring Size dnewman9 Defender Technical Discussions 0 September 5th, 2004 12:30 PM
