FYI: Heater for D-90 - Found...where to install - Defender Source
Old December 7th, 2009, 08:33 PM
PMKColorado's Avatar
PMKColorado
Paul Koentges
'95 White D-90, #2625
Just purchased Flex-a-Lite heater from Amazon for $38...scratch & dent; others available from $52. Will install over the holidays...pictures and heat results to be posted. Thinking about installing in center or rear cubby, depending on fit. Passenger seat compartment used for amp...other ideas appreciated. Don't really want to cannibalize my sheet metal…
(Old Post From Vlocci)
"I just installed a Flex-a Lite Mojave heater under the passengers seat. It is a nice self contained unit that pumps out some serious BTU's. It is simply T'ed into the heater core supply and return lines with 5/8 heater hose, and comes with all the necessary wiring.
real nice unit, about 150.00 bucks, and can easily roast you out of the truck if need be.
If your really intersted, I can snap some pictures, but honestly this is a no-brainer. "
Old December 8th, 2009, 02:07 PM
Raleigh D90's Avatar
Raleigh D90
Ben
Somewhere Across Town
Be careful that you didn't end up with just the plenum. The heater itself is usually $150 bucks or so.
Old December 9th, 2009, 10:23 AM
PMKColorado
Paul Koentges
contacted the seller to ask same question...said it was the heater, however, I suspect it is just the "plenum heater"If not, I may just buy small heater cores, ($10), 6" 12V fans & 2 spd switch, and fabricate/install them in my rear cubby boxes; I would cut/crimp vents directly in the side of the boxes...probably looking at $100 or so for all the parts for two heaters. May need to add an inline pump to help circulate the water...
Old December 9th, 2009, 10:32 AM
I've got one you can copy if you want, its pretty neat. I'd have to take pix.
90, d-90, heater
Euro 90 Swingout tailgate / POE liftgate install dave_lucas Smaller Projects 24 March 14th, 2016 04:01 PM
Heater core ?? & FYI D90user Defender Technical Discussions 4 October 14th, 2005 03:27 PM
Heater Improvements? And Hi ... again.. EdF Defender Technical Discussions 6 September 13th, 2005 01:51 PM
PIAA 90 PRO XT (top) install questions... norros Defender Technical Discussions 22 June 30th, 2004 05:31 PM
