Fuses Keep Blowing - Defender Source
Old December 12th, 2005, 12:53 PM
boshea's Avatar
boshea
Brian OShea
1995 Defender 90 ST
Fuses Keep Blowing
I purchased a cheap auxillary heater from AutoZone the other day to get a little extra in my truck. The heater worked great for about 10 seconds before it blew the fuse. I have tried using a 7.5 instead of the 10 and it still keeps blowing on me.
Any thoughts or ideas would be appreciated...
Old December 12th, 2005, 01:25 PM
Return it and get another? It sounds defective to me.
Old December 12th, 2005, 04:19 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
They draw around 15 amps or so. I tried one, eventually a 15 amp fuse lasted for a while, but the heat output sucked.
Return it, and pull the vent covers off of the output vents in your heater for a big jump in heat.
-Hans
My oil line fix
My 100k stopped odometer fix
Old December 13th, 2005, 02:58 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
These heaters simply can't work well. Even at 10 amps, which is alot to pull from a lighter plug, they still only produce 120 watts - about the same as a light bulb.
Old December 13th, 2005, 08:21 AM
scoloco's Avatar
scoloco
'94 D90 ST
Heat solution #1 - drop curtain (assuming you have a full st or hardtop).
wing
ATC/ATO Fuses DJ Menasco Defender Technical Discussions 2 September 13th, 2004 05:17 PM
97 D-90 SW blowing fuel pump fuses intermittantly BarryO Defender Technical Discussions 9 July 20th, 2004 03:07 PM
Check Engine Light after I was screwing around with fuses... P1CR Defender Technical Discussions 3 April 1st, 2004 04:56 PM
Blowing Rock, NC WCURoverD90 Trips, Trails and Events 23 December 2nd, 2003 02:16 PM
Fuses? Horn and clock... OCD90 Defender Technical Discussions 3 November 17th, 2003 06:05 PM
