fuseable link is toast - Defender Source
Old April 4th, 2013, 01:58 AM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
Got in the D90 today tried to flip on my headlights and none of my lights come on. Looked under the hood in the fusebox and found thisl the fuseable link/inline fuse had burnt up, which is weird cause the 30 amp fuse should prevent that right? I recently also had to replace my headlight switch cause that melted. Has any body had any similar issues? Not long ago I upgraded my headlights to the Hella pair that AB offers, maybe that has something to do with it.
Old April 4th, 2013, 02:01 AM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
pic of fuseable link
Old April 4th, 2013, 02:09 AM
Another fine reason to run the headlights through a relay.
Old April 4th, 2013, 05:54 AM
I dunno what you got going on there but it's scary. Luckily the bad wiring let go before engulfing the vehicle in flames.
For your and the trucks sake I urge you to wire it safely.
Old April 4th, 2013, 11:23 AM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
what would be a "safe" way of wiring it? I did not install that wire/fuse combination by the way, its been there since I bought the truck; I always thought that was how it was supposed to be.
Old April 4th, 2013, 11:31 AM
That is not a fuseable link. Someone has replaced the factory fuse with a spade fuse holder. I've now item why the holder burned up, but I would remove it and install a proper fuse. First check the rest of the wiring as you must have a dead short somewhere.
Old April 4th, 2013, 11:59 AM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
X2
It looks like someone adapted and aftermarket fuse holder instead of replacing the factory fuse. The clue that its a bodge job is the bare wire screwed in.
I would ger the factory fuse back in there and then get a headlight relay harness (ARB or similar).
Im guessing the switch is cooked, and took out the Kustom wiring.
-Jeff
A headlight relay harness? Just for the headlights? I don't have any auxiliary lights.
Old April 4th, 2013, 12:13 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
Yes just for the headlights. As it is the factory set up runs full power through the switch, which doesn't hold up over time (sometimes only lasting a year). Running a relay harness not only saves the switch, but it makes your headlights brighter, by running power direct to the headlights.
-Jeff
So where would I get a headlight relay harness? And what is it exactly?
Old April 4th, 2013, 12:15 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Looks as if someone cut a corner with an improper fuse. It may have been rated the same but if they did that hack, there is no telling what other short cut the PO took. IMO. Separate harness is the way to go...
Old April 4th, 2013, 12:33 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
For reference so I get the correct fuse can anyone tell me if that fuse is supposed be a 30 amp fuse? The fuse that was in that burnt up wire was a 30 amp.
Old April 4th, 2013, 01:24 PM
Bill Larson
Bill Larson
Here's what I have on my 97SW.
Name:	New Braunfels-20130404-00797.jpg
ID:	69539   Click image for larger version
Name:	New Braunfels-20130404-00799.jpg
Name:	New Braunfels-20130404-00800.jpg
Old April 4th, 2013, 01:44 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
Ok cool, thanks!
Help with rear link removal UpnOver Defender Technical Discussions 19 October 22nd, 2009 05:21 PM
Need new drag link & pitman arm !? Rover- Girl Defender Technical Discussions 4 March 23rd, 2006 06:33 PM
Home design 3 link system UKlandyandy Defender Technical Discussions 65 February 17th, 2005 09:09 PM
Fusable Link by batt on 92 RRC...? RedRhinoProducts Defender Technical Discussions 5 February 6th, 2005 07:23 PM
