Fuse Panel Upgrade - Defender Source
Old June 13th, 2016, 09:45 PM
ghoregon
Greg H
1984 Defender 90 Ex-MoD
Fuse Panel Upgrade
Hi all.
I've bought the AMR3138 bracket and the appropriate fuse block/connectors to upgrade my ex-MoD glass fuses to blade style fuses.
I still need to pick up the correct blade fuses for the job. A couple of questions:
1) MoD increased the amperage over what is shown on the original diagram in a few circuits (see pic). Should I stick with the higher amps with the blade fuses or go back to the original amp level?
2) It doesn't look like blade fuses are widely available in 8A or 12A. Is there a general consensus on whether it is better to go up or down to the next available fuse size?
Greg
Old June 13th, 2016, 10:09 PM
I'd think you would want to go with the lower amperage fuses to protect the circuit. If a certain fuse pops a couple times due to load, then go up a few amps.
Old June 13th, 2016, 11:50 PM
jafir's Avatar
jafir
Jafir Elkurd
Glass fuses and blade fuses are rated differently. One is the rating at which it will blow and the other is the rating of the load it's intended to carry or something like that.
Old June 19th, 2016, 07:54 PM
ghoregon
Greg H
Thanks guys. I will take the blade fuses down to the next available increment and see how it goes. Still haven't tackled the job, the wire "spaghetti" looks a bit daunting to be honest.
Greg
Sent from my SM-T520 using Tapatalk
Old June 19th, 2016, 08:01 PM
jafir's Avatar
jafir
Jafir Elkurd
I'm in the same boat. I'm worried about how long it will take and at least I can drive it right now.
Old June 19th, 2016, 08:21 PM
ghoregon
Greg H
Yours looks like this too? I'm wondering what the disconnected "Rists" connector with the red wires is...anyone?
Sent from my SM-G920P using Tapatalk
Old June 19th, 2016, 09:02 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
There is also another rating which is how fast it would blow (to handle "normal" and temporary surges). No idea is this is a glass-only thing.
MonLand
1995 D90 NAS
1996 Discovery NAS
Fuse Box: Glass fuse --> Spade Fuse gonzanc Defender Technical Discussions 20 October 27th, 2016 11:54 PM
60amp accessory fuse B blowing in main fuse box owen Defender Technical Discussions 5 March 31st, 2013 09:18 AM
Water Pump/fuse panel cover bjenk For Sale - Parts 2 October 19th, 2007 11:10 AM
fuse panel question Overlander Defender Technical Discussions 3 January 2nd, 2007 01:34 PM
94 ST Fuse Panel Cover mfreeman17 Wanted 0 June 28th, 2004 01:30 AM
