fuse panel question - Defender Source
Old January 1st, 2007, 06:24 PM
fuse panel question
I have a few blank fuse holes in my fuse panel, and i wanted to take advantage of them, by adding some fused accessories. Does anybody know the correct female terminal end type to use to add fuse lines to these blanks? I went to an auto store, and they had alot of different types, so I didn't know which ones to pick.
Old January 1st, 2007, 07:21 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Winzer is where I get them. But I usually have one to match up to the local sales reps catalouge. If no one here helps you on this, I'll see what I can do.
JP
legend in my own mind
Old January 1st, 2007, 09:11 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Jim what is Winzer?
CB
Old January 2nd, 2007, 01:34 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Winzer
Never did a online search for them. They are a dealership type parts supplier. Electrical parts, fluids, washers etc...
I'll check Online for ya
JP
winzerusa.com
winzerwurth.co.uk for the limeys
Fuse Cover Panel MEUSOC Wanted 0 September 18th, 2009 06:55 PM
Fuse panel bracket rayfi Wanted 1 November 26th, 2008 07:16 PM
SW Interior Door Panel Question mgrgpg Defender Technical Discussions 8 July 24th, 2007 11:00 AM
94 ST Fuse Panel Cover mfreeman17 Wanted 0 June 28th, 2004 01:30 AM
