Fuse Box Replacement for Defender Style ROW Vehicles - Defender Source
Old January 6th, 2016, 10:54 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Over the years, have spent way too much time trying to correct the short comings of the round glass fuses behind the center dash cover on ROW Defender style vehicles.
After spending hours cleaning, sanding, spraying the fuse clips without contiguous reliability I have been replacing the fuse boxes for years with various 6 X mini-fuse boxes.
The mini fuses are easier to install and replace than the glass fuses.
This month, I finally found a fuse box that will fit in the original space and take a soldered spade connector from underneath.
This makes replacement very easy.
You clip the wire(s) on each position, strip the wire, attach the wire(s) to the spade connector, solder the connection and slide the spade into the underside of the new mini-fuse box.
The result is that all the wires reach and the replacement is 1 to 1 for the original, so the original fuse legend is still identical to the fuse positions on the new fuse box.
When I get a little time, will remove the metal fuse box surround and install 2 of these fuse boxes, replacing the original ones. There is also loads of room to trim the surround to make room to add additional fuse boxes for auxiliary custom wiring.
Will update this thread when I get more time to conduct an install.
The fuse boxes are made in Italy and not sold to individuals, but think I can supply a kit with fuse boxes and solder on connectors for about $49.
ID:	138671   Click image for larger version
RDavisinVA
Old January 6th, 2016, 11:08 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
I'm in for a kit.
~ Semper Fidelis ~
Old January 6th, 2016, 11:15 PM
ATX_D110's Avatar
ATX_D110
Victor
1985 RHD D110 (SOLD)
In as well
Old January 6th, 2016, 11:21 PM
Robert,
You are re-inventing the wheel. Here's what I use. PRC 4826-The factory 300 tdi vintage box. By using the correct fuse box you can get the correct fuse box label for a clean correct install. The special crimper for the connectors ads to the cost but makes perfect factory type crimps.
20 Way Bulkhead Blade Fuse Holder Box And Terminals - Land Rover - PRC4826 | eBay
Old thread here on the same subject
fuse panel connectors - Defender Source
Old January 7th, 2016, 04:54 AM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
If we order within the next 5 min, will you throw in a set of Mercedes engine mount adapters (Mercedes engine mounts sold separately)?
Old January 7th, 2016, 06:04 AM
All you pay is shipping of $19.99.....
Old January 7th, 2016, 08:04 AM
rovertrader's Avatar
rovertrader
Dale
and handling of $49.99....
Old January 7th, 2016, 09:25 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
That is funny stuff.
RDavisinVA
Old January 7th, 2016, 09:31 AM
Who ?
Old December 18th, 2016, 11:52 AM
yankee
Bala
Robert,
Uncle Doug, what crimper should be used for this? Also this fuse box needs cutting the panel I guess? Probably mount it horizontal on the top of the panel? Thanks.
Old December 18th, 2016, 01:41 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yes, I need a new crimper, too.
Not for my fuse box but for all around good crimps as I no longer solder.
Rent my
Old December 18th, 2016, 01:47 PM
yankee
Bala
I have bought some ok tools from HF for wire stripping and crimping. Its always been a struggle to get the work done efficiently. Would this be a good all around stripper?
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
And a good all around crimper?
https://www.amazon.com/Titan-Tools-1...DMERSKZ89E08F4
Old December 18th, 2016, 01:54 PM
The_Vermonster's Avatar
The_Vermonster
Gordon
1984 110 CSW
I like the old fashion multitool.
https://www.amazon.com/VISE-GRIP-Mul...ttl_B000JNNWQ2
Does almost everything. Get a special crimper when you need to do special terminals.
Old December 18th, 2016, 02:07 PM
This is the one I have Ratcheting Crimping Tool for Terminals
Old December 19th, 2016, 06:31 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I use a slightly different one. If you happen to re-pin some connectors this does them all even the very small ones.
https://www.amazon.com/s/ref=nb_sb_n...ds=hozan+p-706
Land Rover 110
Old December 19th, 2016, 08:58 AM
yankee
Bala
Thanks. Looks like its out of stock. Would this be the same or was the one you suggested specific for the LR application?
https://www.amazon.com/Tool-Aid-1890...g+wire+crimper
------ Follow up post added December 19th, 2016 08:59 AM ------
I have two of those and could never get adapted to it for some reason. Need a dumb user version!!
------ Follow up post added December 19th, 2016 09:00 AM ------
Same as above!
Old December 19th, 2016, 02:47 PM
Capt Milks's Avatar
Capt Milks
I have used it a lot and wouldn't do with out it anymore. It did take a while and trashed some connectors before I got use to it.
Land Rover 110
Old December 19th, 2016, 03:15 PM
https://www.amazon.com/dp/B01G850VMW?psc=1
ac, defender
Fuse Box: Glass fuse --> Spade Fuse gonzanc Defender Technical Discussions 20 October 27th, 2016 11:54 PM
60amp accessory fuse B blowing in main fuse box owen Defender Technical Discussions 5 March 31st, 2013 09:18 AM
Cover fuse box for defender new in box and lev-o-gage sr jonathon For Sale - Parts 2 December 3rd, 2012 06:39 PM
fuse box replacement suggestions Gkase Defender Technical Discussions 2 March 28th, 2010 02:10 PM
Non A/C Style Fuse Box Cover mhill Wanted 0 June 26th, 2009 12:15 AM
