Fundamentals - how to figure out plug order - Defender Source
Old April 26th, 2007, 08:52 PM
chuff's Avatar
chuff
'94 D90
Really basic question -- how do I figure out what order the plugs should go back into the dist cap? I pulled them off last night looking for moisture/corrosion and completely forgot to keep them in order. Thanks
Old April 26th, 2007, 09:11 PM
its in the owners manual, and i think it might be on a sticker under the hood, that may be a delusion.. I know its in the manul for sure tho
Old April 27th, 2007, 10:38 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
firing order is 1-8-4-3-6-5-7-2
distributor rotates clockwise
turn the crankshaft until the timing pointer is at the TDC mark. If the rotor tip points towards the drivers side headlight, you are at TDC for cylinder #1, if the rotor tip points the other way, you have found TDC for cylinder #6.
reinstall plug wires from there.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old April 27th, 2007, 12:49 PM
chuff's Avatar
chuff
'94 D90
Thanks for pointers, I'll take care of it tonight.
Out of curiousity, can harm be done by mixing up the plugs and turning the ignition?
OBD Plug no power??? Cyborg Defender Technical Discussions 4 December 29th, 2005 11:29 PM
what does this plug in to? mattdh Defender Technical Discussions 6 November 2nd, 2004 11:59 PM
What does this plug go to??? Chris Cox Defender Technical Discussions 1 July 11th, 2004 03:24 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
Serial Link Mating Plug? Ramsay Defender Technical Discussions 9 May 13th, 2004 11:27 PM
