fuel temp sensor - Defender Source
Old May 13th, 2006, 02:22 AM
mattdh's Avatar
mattdh
Matt Hurst
fuel temp sensor
what exactly does the fuel temp sensor do? my guess is that it monitors the fuel temp of the rail and shuts of the fuel supply if it gets to hot???? how can you tell if its gone bad?
Old May 13th, 2006, 12:25 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I think it also tells the ECU of the fuel temperature to help adjust the mixture as well, but not 100% sure of that. However, it does route through the ECU, so you should get a check engine light if it's bad.
Don't remember anybody here ever saying they had to replace one, and it's a touch pricey.... I think around $80.00 or so.
-Hans
My oil line fix
My 100k stopped odometer fix
Old May 13th, 2006, 08:59 PM
mattdh's Avatar
mattdh
Matt Hurst
it is pricey but i did see it at bp fo $39
fuel, sensor
Fuel Temp Sensor engine code Tim Scully Defender Technical Discussions 0 January 9th, 2008 08:34 PM
