Fuel tank swap questions... - Defender Source
Old May 8th, 2016, 03:17 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
The fuel tank on my RHD '85 Ninety V8 is leaking. I presume the correct replacement is PLI-135? My fuel filler is on the right (drivers side, on a RHD) with the filler in front of the rear wheel?
Anything else I should replace while I'm in there?
I plan on painting the tank with rubberized stuff before installation.
Thanks in advance.
Paul.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old May 8th, 2016, 03:42 PM
That does not sound like a Land Rover part number.
Be aware the factory installs them with the seat box out. With it in, you can do it but it is tight and a fun job.
Old May 8th, 2016, 04:11 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
It's a Rovers North part number.
I'm prepared for the swap to be a PITA, just like every other job on this thing!
Old May 15th, 2016, 09:24 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Well, that sucked. Out rigger rotten, new tank bigger than the old one & thus a PITA to install, was sent the wrong size bolts & to top it off, fuel guage doesn't work now. Boo!
Old May 16th, 2016, 01:53 AM
smenzel's Avatar
smenzel
Sandro
1967 Series IIA
Fuel gauges are supposed to work?
Mine goes between reading low to reading high depending on the time of year or some other mystifying criteria. I use the trip odometer as my fuel gauge.
fuel, fuel tank
STC1139 Fuel Tank Unit 90 w/ In Tank Pump 89Defender90 For Sale - Parts 0 March 28th, 2015 02:13 PM
Aluminum traction sand mats and aux fuel tank / water tank jonathon For Sale - Parts 7 December 11th, 2012 03:14 PM
Defender 90 Fuel tank - Disco 97 / 98 tank thpsmr Defender Technical Discussions 15 December 9th, 2011 11:44 AM
Diesel fuel tank vs. Gas tank Tyler Wirken Defender Technical Discussions 9 January 28th, 2010 07:25 AM
I am dropping the fuel tank and I have a couple of questions, help QUEST Defender Technical Discussions 24 September 26th, 2009 03:26 AM
