Fuel tank pressure with a 200tdi - Defender Source
Old September 18th, 2013, 07:29 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I have the filler neck pictured below and the gas cap also pictured. When I started my truck I had a hissing coming from the fuel filler cap, it also started to leak from the mystery spot, that it has been leaking from for a while. As soon as I loosened the cap it stopped, the hissing and the leaking. I'm assuming that I have the wrong cap on the filler because it doesn't relieve any of the pressure.
Am I right in thinking that an NAS fuel cap won't work with a diesel?
ID:	80249   Click image for larger version
Old September 18th, 2013, 08:49 PM
Diesel or gas both systems have a low pressure flow back to the tank- nothing that should pressurize it. When you take the cap off is there pressure escaping or suction ?
Either way- try a new cap.
Old September 18th, 2013, 09:01 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Pressure escaping
I am dropping the fuel tank and I have a couple of questions, help QUEST Defender Technical Discussions 24 September 26th, 2009 03:26 AM
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
Leaky Fuel Tank cbass Defender Technical Discussions 12 June 2nd, 2005 04:50 PM
Air filters and a bad fuel tank valve thingy! RickM Defender Technical Discussions 1 August 9th, 2004 03:29 PM
