fuel tank insall - Defender Source
Old July 2nd, 2008, 11:49 AM
rgrrvr's Avatar
rgrrvr
DJ Menasco is The Dude
1995 D90
fuel tank insall
does the D90 tank just drop right in with the bottom plate or is there some padding that is supposed to go under it? I know about the closed cell foam dics along the sides but it seems like there should be something along the bottom or a top strap to keep it secured. Or is it just free to bounce around or rub on the bottom plate? I looked through the parts manual but didn't see anything, and checked out BarryO's thread but just thought I'd ask...
...you'll feel better in a couple of days.
Old July 2nd, 2008, 12:02 PM
Grover's Avatar
Grover
Only the skid plate holds the tank in place. To my knowledge, there is no padding on top or on bottom of the tank. Be sure the tank is near empty before dropping the plate.
Good luck...
Cheers...
Old July 3rd, 2008, 08:36 AM
No padding, but it gets wedged pretty tight between the tub and the skid plate. The filler seems to hold it in place pretty well too.
Old July 5th, 2008, 11:37 AM
slickrock
Andrew Gold
94 D90
Watch out for the evaporator hoses. If you rip the bushings going to the tank you may not notice the leak until you button everything up, take a turn on a full tank, and smell gas.
Has anybody ever cut out an 8-inch port hole in the back of the floor board to get to the fuel pump? A nice plexiglass cover or a stainless steel plate would could look trick and make the future replacement of a fuel pump a half hour job.
Old July 5th, 2008, 11:48 AM
D90DRC
D Cantrell
1997 D90SW
I was thinking of using a large boat scupper to plug the hole. It has an oring and looks like it was made that way
Old July 5th, 2008, 12:38 PM
You could always use the floor plug from a rangie or a disco, but I'd rather pull the tank every few years than cut my floor.
fuel, fuel tank
I am dropping the fuel tank and I have a couple of questions, help QUEST Defender Technical Discussions 24 September 26th, 2009 03:26 AM
Leaky Fuel Tank cbass Defender Technical Discussions 12 June 2nd, 2005 04:50 PM
Air filters and a bad fuel tank valve thingy! RickM Defender Technical Discussions 1 August 9th, 2004 03:29 PM
How much work to drop the fuel tank? BarryO Defender Technical Discussions 5 July 15th, 2004 06:06 PM
