Fuel tank for upgraded 4.6? - Defender Source
Old May 16th, 2015, 08:32 AM
jason1st
Jason Crandall
2006 LR3 2012 SC 1983 110
Do I need a whole new fuel tank assembly on my 1984 110 for an upgraded GEMS 4.6? Or can I just get a new pump and use the existing tank?
Old May 16th, 2015, 09:14 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
When I fitted a 3,9 efi into my old 90 (with the euro side tank), I just used an in-line fuel injection spec pump. worked a treat. Vehicle was originally a 200Tdi, and I used the same diesel pickup pipes.
Old May 16th, 2015, 10:21 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
Why would you need a new pump or tank...what am I missing?
Old May 16th, 2015, 10:32 AM
The existing pump will be low pressure. You can just use an external aftermarket pump.
Old May 16th, 2015, 10:58 AM
Bill Larson
Bill Larson
This is petrol...why is there a difference? A higher pressure would be require for what? the distance is the same. Is there an injection pressure difference? Just curious because in my configuration no pressure reconfigurations were required. This is a 3.9 to 4.6 right?
Old May 16th, 2015, 11:08 AM
He had an 84 engine. It would have been carbs and low pressure. The new engine is efi and high pressure.
Old May 16th, 2015, 11:12 AM
Bill Larson
Bill Larson
Ah...well there you go! lol...
Old May 16th, 2015, 12:55 PM
jason1st
Jason Crandall
New engine is 4.6 EFI.
Old engine is a carbed 3.5
So I definitely need whole new tank assembly or an external pressure pump? Is there a downside to the external pressure pump vs. new tank with internal high pressure pump? Just another pump to fail? I'm a "do it right the first time" kinda guy.
Jason
Old May 16th, 2015, 01:15 PM
Either will work fine. Obviously an external pump is easier to access if needed. The external is probably a little louder. Make sure there is a proper EFI fuel filter after the pump.
Old May 16th, 2015, 06:44 PM
jason1st
Jason Crandall
Can you post a link of an external high pressure pump and filter that will work?
Old May 17th, 2015, 01:45 AM
jafir's Avatar
jafir
Jafir Elkurd
Don't 110 and RRC have the same tanks? If it's got the hole in the top can't you just drop an early metal RRC fuel pump into it?
Old May 17th, 2015, 06:57 AM
jason1st
Jason Crandall
That's the question I'm asking. Is an early RRC full pump "high pressure"?
Old May 17th, 2015, 07:28 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
87-90 RRC use the metal tank & EFI pump… same as the 93 110. Not sure how that translates to your 84.
Old May 17th, 2015, 08:02 AM
jason1st
Jason Crandall
Here is the link to the NAS 110 fuel pump. It says:
"Fits vehicles with steel tank that have a separate pump and sending unit."
What does that mean?
FUEL PUMP V-8 EFI NLA USE PLF131, RNF131, PRC8318 - Rovers North - Classic Land Rover Parts
Old May 17th, 2015, 08:08 AM
jafir's Avatar
jafir
Jafir Elkurd
That's saying it doesn't fit the later RRC that uses the big disco style plastic fuel pump with the built in sending unit.
Is your tank metal? Does it have a big hole in the top? It looks like some early 110 just have a hole in the side of the tank. I'm guessing if it's got a hole in the top you can put the RRC fuel pump in it, from an early RRC with FI. If it's had FI, it's high pressure.
Old May 17th, 2015, 08:12 AM
jason1st
Jason Crandall
Yes, my tank is metal and has the hole in the top.
So a new 4.6 doesn't have a different pressure need than a '93 NAS?
Old May 17th, 2015, 10:15 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
IIRC all the EFI's used the same pressure controlled by the FP regulator.
Like Jafir said, if you have the hole on top and the separate sender on the side it may work. I can measure the diameter on the pump if that helps in anyway.
fuel, fuel tank
STC1139 Fuel Tank Unit 90 w/ In Tank Pump 89Defender90 For Sale - Parts 0 March 28th, 2015 02:13 PM
Aluminum traction sand mats and aux fuel tank / water tank jonathon For Sale - Parts 7 December 11th, 2012 03:14 PM
Defender 90 Fuel tank - Disco 97 / 98 tank thpsmr Defender Technical Discussions 15 December 9th, 2011 11:44 AM
Diesel fuel tank vs. Gas tank Tyler Wirken Defender Technical Discussions 9 January 28th, 2010 07:25 AM
upgraded axels? ripp2002 Defender Technical Discussions 5 September 30th, 2005 12:57 PM
