Fuel system questions? - Defender Source
Old February 4th, 2007, 06:04 AM
DIVERPRO
Tamer Adel
Talking Fuel system questions?
Hi
I was wondering if some one can help me with a no. of questions?
I have a 1984 V8 landrover 90 in Holland.
It has two carbs that gives me a lot of problems and I need to replace them together with the manifold with a single carb. I already have the part no for an edalbroke carb and maifold, however, the summit racing site that i am planning to purshase from says that these edelbroke carbs fit only from 1987 models on and I was wondering if some one has a pervious experience with this?
would they fit on the 1984 landrover or not?
I also need to change the fuelpump any suggestions and part no.?
and there is a talk about the need for a mouting prackets for the change, any info?
and finally can i do this all by myself or i will require pro. help?
thank you very much.
fuel
I am dropping the fuel tank and I have a couple of questions, help QUEST Defender Technical Discussions 24 September 26th, 2009 03:26 AM
95 D90 Fuel System steinhnj Defender Technical Discussions 8 November 28th, 2008 12:25 PM
