Fuel stop solenoid failed again - Defender Source
Old August 22nd, 2016, 05:12 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
The second day I had my truck it wouldn't turn off. Pulled wire on stop solenoid, no change. OK solenoid stuck. Replaced solenoid with a Bearmach unit. All well and good. A couple weeks goes by till today. Turn truck off, stays running. Pull wire off solenoid, and it stays running. Stall it out.
What gives? Crappy quality solenoid (It was only $8) ? Something in fuel (changed filter 2 weeks ago)? I am annoyed I have to do it again. I don't mind paying the money for a better quality part. I just don't want to be updating this thread in two more weeks with the same issue again. The original solenoid appeared to be OEM, I believe it said Bosch on it.
Any tests I can run? I seems pretty clear to me it is a mechanical problem since it stays running with the wire off.
I don't mind paying $21 for the FLAG or $115 for the Bosch if it means better quality. Especially if I don't have to do this again.
Old August 22nd, 2016, 05:30 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
We have Bosch ones for 200/300 TDI for $39.99 + $6.80 Shipping with a 1 year warranty.
RDavisinVA
Old August 22nd, 2016, 05:33 PM
AdamSanta85
91' D90 200TDI
Killer, ill send payment. I think I'm going to replace lift pump too.
Old August 22nd, 2016, 05:38 PM
When you remove the failed one this time, stick a magnet on a stick, $3 at most auto parts stores down in the hole in the IP. As the rotary pumps wear that's where metal shavings seem to end up. I have puled scary amounts of metal out with a magnet from a truck that otherwise ran great. YMMV
Old August 22nd, 2016, 05:52 PM
AdamSanta85
91' D90 200TDI
Oh boy. That's what I had in mind, not what I wanted to hear.
Old August 23rd, 2016, 09:09 AM
AdamSanta85
91' D90 200TDI
Thanks for the advice.
I think I am going to pickup a new lift pump. Also install a electric Airtex fuel pump and sedimenter and new line from tank to LP. I have a sedimenter on the way from RDavis. I see the way this is going and want to be proactive. I don't want to chance running the IP dry and having a $$$$ failure, which I may be already showing signs of.
Assuming Delphi lift pump is the one to get vs Bearmach? They are same price. I am not going $250 for a Genuine.
Old August 23rd, 2016, 11:06 AM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
Which engine?
For my 2.5na, when my white box one failed, I installed a FLAG while I went looking for a Delphi which I carried as a spare. The FLAG lasted ~1.5 years and ~2K miles before it failed. We'll see how long the Delphi lasts. If your engine's choice is white box, FLAG or Bosch, go for Bosch.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old August 23rd, 2016, 11:12 AM
AdamSanta85
91' D90 200TDI
Originally Posted by pitchrollyaw View Post
Which engine?
It's a 200TDI. I ordered the Bosch from RDavis. Hopefully between that and stucking a magnet in the hole to check for metal shavings will do the trick.
Oddly enough I also notices there is no spark when attaching the connector to the solenoid when running, like there was when I replaced the first one. That being said with the electrical disconnected regardless it should shutoff as it is a mechanical system, so who knows.
Ill update when I get the new stuff to install.
Old August 23rd, 2016, 11:33 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Anything at all can stop that plunger from operating correctly.
Mine had a single cloth fiber (thread) that caused my "no stop" issue.
Old August 27th, 2016, 01:03 AM
Thiemo's Avatar
Thiemo
Thiemo Ebersberger
1989 4 door pick up 110
Check for metal shavings! Running a fleet of 12 Defenders i have had this a few times. It starts with the Stop solanoid failing for about three times in ever shorter distances. Shortly after the injector pump fails. It could be a sign that your pump is slowly destroying itself.
Old August 27th, 2016, 06:03 AM
AdamSanta85
91' D90 200TDI
If i find shavings what then? Can the pump be rebuilt or am I screwed? This thing only has 80k miles on it
Old August 27th, 2016, 07:45 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You can send it to Blue Ridge Diesel in Salem, VA for a rebuild.
RDavisinVA
Old August 27th, 2016, 08:23 AM
pitchrollyaw
wayne p
1985 d90 2.5NA
What is the failure mode for death by shavings? Does it cause them to leak or not activate/shut off?
Mine had two go, but they both failed where the plastic insulator seals to the solenoid body. One insulator melted, deformed a bit and leaked while the second just started spaying fuel from the joint. This failure mode seems to be more of a quality issue. Thanks,
I'm running a Delphi now, so we'll see how it goes.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old August 27th, 2016, 10:33 AM
fraser61's Avatar
fraser61
Fraser Gourlay
1986 D110 TUM 300Tdi
I had a similar experience, just on my 300TDi and going cheap on the solenoid was the root cause in my opinion. The Bosch item though expensive almost guarantees you flawless starts and stops.
Cheers
Fraser
Fras61
2008 RRS SC
1986 D110 Tithonus 300TDi RHD
1979 S3 Lightweight
2006 ZX-10R
Beauty is in the eye of the beholder, get it out with eye drops.
Old August 27th, 2016, 11:17 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by fraser61 View Post
Adam I had a similar experience, just on my 300TDi and going cheap on the solenoid was the root cause in my opinion. The Bosch item though expensive almost guarantees you flawless starts and stops. Cheers Fraser
thanks! Some parts I swear just don't pay to save $ on.
Old August 27th, 2016, 11:57 PM
Thiemo's Avatar
Thiemo
Thiemo Ebersberger
It can be rebuilt. The pump is lubricated by the diesel going trough it. In general they last for nearly ever. Main causes for failure is crap diesel. If you have a lot of water in it the elements start rusting and give up pretty quick. Also which is common here in Africa the stations mix it with kerosin or parrafin to increase their profits. Kero has a cleaning effect and stops the lubrication. Not sure what mixed in bio fuels are doing. Possibly the same effect.
Old August 28th, 2016, 11:22 AM
1of40's Avatar
1of40
1of40
FYI If anyone happens to be in a pinch and rather not stall your truck to get it to stop, try reving the engine up(in neutral) and it may turn off properly.
top, fuel
2.5na stop solenoid pitchrollyaw Defender Technical Discussions 3 August 10th, 2016 10:59 AM
300tdi no start stop solenoid clicks Broncoduecer Defender Technical Discussions 28 March 6th, 2015 11:22 PM
2.5NA stop solenoid...melted pitchrollyaw Defender Technical Discussions 19 August 13th, 2014 12:50 PM
Two Weeks in Utah chris snell Misc. Chit-Chat 9 March 24th, 2011 03:54 PM
LA for two weeks spotted first Defender bharris Misc. Chit-Chat 40 March 9th, 2010 06:50 PM
