Fuel smell! - Defender Source
Old January 13th, 2014, 03:31 PM
Landyman1's Avatar
Landyman1
Landyman
1983 land rover 110 county
Fuel smell!
Hey chaps, for some reason when the landy is running there is a somewhat strong smell of petrol. It is obviously worse outside the car and may be expected but it is the fumes on the inside that worry me. At times, the smell can get a bit strong and headache inducing. Does anybody have any ideas on where the smell may be coming from, where to find it, and how to fix it?
Old January 13th, 2014, 03:47 PM
usadventureracing's Avatar
usadventureracing
Brett
110
i am also interested in responses to this question as I have the same issue with my 83 110.
1983 ROW D110
1970 Series III (Parting out)
Old January 13th, 2014, 04:15 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Sumthin' is a leaking somewhere!
Old January 13th, 2014, 04:21 PM
You have to look for the leak. There is no way that people on the internet can figure out the location.
Old January 13th, 2014, 04:38 PM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
Same thing happened when I first bought my truck and it turned out to be a manifold gasket.
Old January 13th, 2014, 04:39 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
If you have no visible fuel leak you may have a detached vapor line on your tank. Has anyone tinkered with your fuel tank lately? In order check that out you'll have to drop the tank potentially.
You could lower the tank slightly and use an flex inspection camera to check it out. When you max out your tank when fueling you should leak fuel from the tank area if a hose is loose or detached.
Old January 13th, 2014, 05:35 PM
usadventureracing
Brett
110
I am sure it is my manifold gasket.
1983 ROW D110
Old January 13th, 2014, 05:53 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You'll need to look look look.
I always take a brief look under the hood (bonnet) and if there is no visible drips get under the vehicle with it running and start at the tank and work forward. Look for drips and cracked fuel lines.
Every 2.25 or 2.5 petrol import I've ever seen had cracked fuel lines back by the tank that leaked gas.
Keep a fire extinguisher or 2 in your vehicle at all times and don't let anyone smoke anywhere near it.
You gave us very little to go on like posting which engine you have for a start.
It always amazes me when I see a post like yours... we need more info to help us help you!
BTW: this is not meant to slight you in any way, people here actually want to help.
RDavisinVA
Old January 14th, 2014, 12:42 PM
Landyman1's Avatar
Landyman1
Landyman
Originally Posted by rdavisinva View Post
You'll need to look look look. I always take a brief look under the hood (bonnet) and if there is no visible drips get under the vehicle with it running and start at the tank and work forward. Look for drips and cracked fuel lines. Every 2.25 or 2.5 petrol import I've ever seen had cracked fuel lines back by the tank that leaked gas. Keep a fire extinguisher or 2 in your vehicle at all times and don't let anyone smoke anywhere near it. You gave us very little to go on like posting which engine you have for a start. It always amazes me when I see a post like yours... we need more info to help us help you! BTW: this is not meant to slight you in any way, people here actually want to help.
of course! Sorry, I knew I was forgetting something. The landy is a 1983 110 with a carbed 3.5l v8 (the early ones). If you need any more info, let me know.
Old January 15th, 2014, 10:14 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
On the V8 check the valley area between the 2 cylinder heads (in the middle of the engine). Fuel can leak in a hidden manner into this V8 abyss and evaporate leaving only the nose to recognize the leak which remains unseen.
It is also common for drips out of the side drafts to vaporize on a hot manifold.
Also check the overflow pipes which often channel overflow from a side draft down underneath the engine.
Combine these tips with what you read above.
Time for some good lighting and intense investigation.
This needs priority as gas fumes are highly flammable, explosive, dangerous, and so on.
It's up to you now!
RDavisinVA
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
Smell of fuel Campbell Defender Technical Discussions 2 March 4th, 2004 02:55 PM
