Fuel skid pain in butt - Defender Source
Old June 24th, 2004, 12:10 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Got Dave's stainless fuel skid yesterday and started soaking the bolts that hold the old one in place in oil. Got the two bolts up under the bumper loose with little problem. The four that sit on the bottom are a different story. Won't budge. I did manage to break a socket trying to get them off. So any ideas? I'm soaking them in more oil right now and am going to try again later this afternoon.
Jimmy Buffett
Old June 24th, 2004, 12:19 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
This may be a silly question. Did you run your fuel level down as close to empty as possible? A full or even half tank is going to put a lot of weight on those bolts.
Old June 24th, 2004, 12:26 PM
flippedrover
Tyler
'94 D-90
it's about half. I have the tank supported by straps.
Jimmy Buffett
Old June 24th, 2004, 01:05 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Do yourself a flavor use PB Blaster it is the best penetrant on the market or Busty. Make sure you get fluid on both sides of the bolt if possible. Also, try an impact driver with a socket & go in both directions that should do it.[ use a big hammer ] At the least break it loose.
Old June 24th, 2004, 01:08 PM
flippedrover
Tyler
'94 D-90
Almost used a full can of PB Blaster. Wish I had air tools. Might be a reason to get some.
Jimmy Buffett
Old June 24th, 2004, 01:32 PM
Tyler, I think Peter is talking about actual IMPACT drivers, you hit it with a hammer and it turns the bolt like 1/8 turn or something. They only cost like $20 and then you only need a matching impact socket. You can always drain your tank like Pete did at Paragon .
Old June 24th, 2004, 01:41 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Yes it's time to get some air tools. I had the same problem with the bolts and used my impact gun and they came off easy.
World traveler
Old June 24th, 2004, 01:52 PM
J4hand
James Forehand
83 110 200tdi
I had the same problem with those bolts too. Soaked them for a while with the PB. I broke three off with a long box ended wrench and a ratchet. Although offering more torque to start it turning, those put too much side stress on the bolt on its way out and snapped it off. Don't go there. They need upward pressure - impact driver, impact wrench, etc.
James
Old June 24th, 2004, 02:08 PM
OCD90's Avatar
OCD90
Torrence
1997 Hardtop
Thanks for posting this. I was about to do it this weekend with hand tools. With no access to air tools, maybe I'll just hand this one over to a friendly/cheap shop I know...
Old June 24th, 2004, 03:51 PM
flippedrover
Tyler
'94 D-90
Ok after using an entire can of PB I have managed to get 4 out of the 6 to budge. I'm going to let the stuborn 2 soak untill tomorrow before I try again. If all else fails I'll rip the skid off since its so rusty and stick some wood under it as a temporary fix then get some air tools.
Jimmy Buffett
Old June 24th, 2004, 04:07 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Tyler, try an impact DRIVER. This is not air operated & is struck with a hammer. They are usually used for philips or slotted screws. Pull the end off & place a socket on the end. Spend the doe for one of these u will use it more than you could imagine. They are cheeeep. BUT handy!!! You could also try some eletrical contact cleaner then back to the PB. The electrical cleaner might help it is thiner & will help the penetrant work better.
Peter
Old June 24th, 2004, 04:45 PM
andys
Andrew Swieck
yeah I broke a few off as well, get yourself a good set of sharp drill bits and some cutting oil, I drilled em out with no problem, used a tap to clean out the treads a bit...
andy
Old June 24th, 2004, 05:59 PM
flippedrover
Tyler
'94 D-90
Thanks. I'll probably get the impact driver just incase. I assume I can get them at a Home Depot type place.
Jimmy Buffett
Old June 24th, 2004, 07:54 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Tyler,
You might want to consider cleaning out the holes with a tap before reinstalling the new bolts that came with the skid plate.
The bolts can be a bit of a pain (understatement of the year) I am constantly amazed at how bad stuff rusts on Land Rovers.
Would you mind taking a picture of your stock gas tank skid plate when you get it removed? I have wanted to see what one from the east coast looks like, I know mine was really bad and my 90 was in Texas and Colorado most of its life.
Torrence,
You might get lucky since your truck is from the west coast
Might as well soak the bolts with some WD-40 or PB blaster and see if they are easy to remove. You can take them out one at a time and see how it goes then decide if it is worth paying someone else.
Just a thought
Old June 24th, 2004, 08:02 PM
flippedrover
Tyler
'94 D-90
Sure thing Dave. I will say it's not pretty.
Jimmy Buffett
Old June 25th, 2004, 11:53 AM
flippedrover
Tyler
'94 D-90
Finaly got the damn thing off. Only broke one of the bolts too. Now for the fun part. Putting the new one on. Here are some pictures of my old skid.
And some others.
ID:	912   Click image for larger version
ID:	914   Click image for larger version
Jimmy Buffett
Old June 25th, 2004, 12:44 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Holy cow. That is rot!
Old June 25th, 2004, 12:53 PM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
What a waste... you could've probably gotten at least another 10 years on that.... LOL
Glenn
Old June 25th, 2004, 12:58 PM
kiefffff's Avatar
kiefffff
Keith Rider
1994 Portofino ST: #217
WOW! Wonder what mine will look like? I'll try and post pics.
94 Defender
11 Toyota FJ
Old June 25th, 2004, 01:11 PM
flippedrover
Tyler
'94 D-90
I'll be more than happy to ship it up to ya Glenn if you want to add it to your truck
Jimmy Buffett
fuel
Fuel tank skid plate GeoParth Defender Technical Discussions 53 June 25th, 2006 03:21 PM
Fuel Tank Skid plate Gore Ranger For Sale - Parts 0 March 14th, 2006 01:22 PM
Fuel Tank Skid Plate sgarrett For Sale - Parts 2 April 10th, 2005 04:09 PM
fuel tank skid plate, bumper, & rotors tonymotosource For Sale - Parts 11 January 26th, 2004 01:20 PM
