Fuel skid pain in butt - Page 3 - Defender Source
Old August 8th, 2004, 02:32 PM
I am guessing yall didnt take off the rear bumper, what did yall use to support the gas tank, please mind my asking... I am going to embark on this endeavour this week I think..
Old August 8th, 2004, 03:28 PM
mlw911
Michael Walter
1995 D90 ST
I used a nylon dog leash to support the fuel tank. Worked like a charm. I think pretty much anything will work to hold it up. I also supported from the underside with a jack stand as a backup.
Michael
Old August 8th, 2004, 04:52 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
I used 2 ratchet straps. One across the back, one run in between the old skid and the tank up front.
Chris von C
[/size]
Old August 8th, 2004, 06:54 PM
cool thanks. I got the bolts undone it was a breeze, I was expecting it a be a bitch from yalls horror stories, long live the PB
Old October 18th, 2004, 10:59 AM
zed111's Avatar
zed111
Zed
1994/Defender 90
Talking Gas Tank Skid Plate Update - Thanks Dave!!!
Dave,
I finally got around to installing your gas tank skid plate and I am extremely impressed with the quality. It is such a major upgrade over the piece of $%*& that was there.
After a bottle of PB I was able to get the bolts off without much of a problem, even though the old skid plate disentegrated. I have attached pictures of the old skid plate, it is amazing that it was able to hold the tank in place. It took me about 2 hours because I cleaned up the surface rust and installed the rear seat belt bracket that sits above the tank.
Thanks again!
Name:	gas skid plate.JPG
ID:	1648   Click image for larger version
Name:	gas skid plate 1.JPG
Name:	gas skid plate 2.JPG
Old October 18th, 2004, 11:10 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
WOW!!!
Skid plate? I don’t see a skid plate in your pictures, just a pile of rust scale
Glad you are enjoying you new skid plate
Old October 18th, 2004, 11:31 AM
Dfndr90's Avatar
Dfndr90
Matt Wunderle
1995 Defender 90
After all these "horror" Stories I went out and looked under the rover, not a lick of rust on the skid plate. My 90 spent all of its first life in Arizona, now that it is in Ohio, should I just be proactive and replace in now, how fast do these things rust out. I just got a case of waxoyl, should I spray the shit out of it and not worry about it for a couple of years. Is nayone elses skid plate in great shape?
Matt...
Old October 18th, 2004, 11:45 AM
I read all this and decided to take mine off and inspect, all was well I sanded and painted with undercoating (3M) and rustoleum since I am poor and couldnt muster the funds for the stainless. If you can I say go for the stainless it is worth it.
Old October 18th, 2004, 11:53 AM
zed111's Avatar
zed111
Zed
1994/Defender 90
Matt...
If you can I would change it before it gets in too bad shape, it makes it much more difficult to change later. I have a low mileage D-90 that has only minor surface rust on the axle and I was shocked at how bad the skid plate was. The previous owner only used it to get too work in the winter in the Northeast.
Dave's is also much higher quality and gives better protection then the stock one.
Old December 13th, 2004, 11:41 AM
Kimos's Avatar
Kimos
Larry O'Hara
1997 Defender Wagon
Well, now this one is my issue too now . . . .
What of Daves skid plate? Details?
I have air rachet. Will I need impact?
And once I get skid any last minute advice before I start my hellish battle of replacement.
Old December 13th, 2004, 12:49 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
“I have air rachet. Will I need impact?”
Hand tools or air tools should be all you need for the bolts. You will also need a ratcheting strap (or 2) to hold the tank in place. Possibly a drill and tap if you bust a bolt.
Well… that and a bunch of PB blaster
“And once I get skid any last minute advice before I start my hellish battle of replacement.”
1. Run the fuel down some so the tank is not as heavy.
2. Pressure wash the area
3. Soak the bolts with PB blaster
4. Soak the bolts with PB blaster
5. Soak the bolts with a little more PB blaster
6. Clean and paint any areas that may be rusty while you have the skid off.
Old December 13th, 2004, 05:05 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
Clean any dirt and girt off the threads of the bolt that are accessible (all but the rear). And soak them. That'll make the front ones easier to take off.
Unfortunatelty, the back two are inaccessible. So when you try to unscrew them, you may end up drawing dirt and grit into the threads, at which point they'll seize up.
Old December 13th, 2004, 07:07 PM
I had no issues with getting access to any of hte bolts on my 95?? fwiw
Old December 13th, 2004, 07:17 PM
Kimos's Avatar
Kimos
Larry O'Hara
1997 Defender Wagon
Thanks!
I guess uh . . . I need some PB Blaster
Oh, and one of them skid plate things too
Hopefully the air rachet will do the trick then
Old December 13th, 2004, 08:09 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Air tools will help i managed to get mine off with hand tools and a can of PB Blaster and Liquid wrench. And a lot of colorful language.
Jimmy Buffett
Old December 13th, 2004, 08:12 PM
did some mention PB Blaster??
Old December 13th, 2004, 11:30 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
"And a lot of colorful language"
I will have to add that to the list of required tools
Old December 14th, 2004, 05:20 AM
flippedrover
Tyler
'94 D-90
I find it comes in very handy when you need to scare the parts off.
Jimmy Buffett
Old December 14th, 2004, 11:38 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
The bolt heads are easy to get to. But on my 97 at least, the threads on the rear bolts are not accessible. Spraying lubricant on the threads works the best.
Old December 15th, 2004, 02:44 PM
Kimos's Avatar
Kimos
Larry O'Hara
1997 Defender Wagon
Dave, sorry for the delay, been at the &*^%&*% auction trying to get the spouse a benz. I received your mail and will be in touch re skid once I get my interior buttoned up this week
fuel
Fuel tank skid plate GeoParth Defender Technical Discussions 53 June 25th, 2006 03:21 PM
Fuel Tank Skid plate Gore Ranger For Sale - Parts 0 March 14th, 2006 01:22 PM
Fuel Tank Skid Plate sgarrett For Sale - Parts 2 April 10th, 2005 04:09 PM
fuel tank skid plate, bumper, & rotors tonymotosource For Sale - Parts 11 January 26th, 2004 01:20 PM
