Fuel skid pain in butt - Page 2 - Defender Source
Old June 25th, 2004, 01:33 PM
OCD90's Avatar
OCD90
Torrence
1997 Hardtop
Oh, mine isn't FROM the West Coast...it's from the Midwest, and it is littered with rust spots...If I could get my hands on one of the Brit metallurgists that have plagued us with these issues...
I'm sure I'll need lost of penetrant...
Old June 25th, 2004, 01:42 PM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
Originally Posted by flippedrover
I'll be more than happy to ship it up to ya Glenn if you want to add it to your truck
LOL
Glenn
Old June 25th, 2004, 01:52 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Luckily my originals don't look as bad as James.
I stupidly left about 3/4 tank in there so I'm probably not going to install this puppy today.
Would the extra weight make it 'that more' difficult ?
Nicholas
Old June 25th, 2004, 02:06 PM
holy shit. what did it look like from the side facing down....
Old June 25th, 2004, 02:10 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Nope. I had 3/4 to 1/2 in it. Use rachet straps and get them tight. Yeah a lot of oil. I had to hammer a 13mm impact socket onto the bottom four bolts. They had taken a few hits and infact the rear most left bolt was bent. Hmmm...wonder how I did that.
Jimmy Buffett
Old June 25th, 2004, 03:23 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
WOW! That is amazing!
Would you mind if I use the pictures on my site?
Old June 25th, 2004, 05:06 PM
flippedrover
Tyler
'94 D-90
Go ahead.
Jimmy Buffett
Old June 27th, 2004, 12:40 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Quick Question to those who have installed this skid plate:
If I don't have 'rachet straps' can I use a jack to hold the tank up ?
I have a little less than half a tank right now, which in reality is probably about 1/3 tank so I may venture out and do it.
Nicholas
Bad idea.
Thanks for the call Dave.
Nicholas
Last Update:
PIECE OF CAKE! Took 15minutes, if that. Bolts came right off without a hitch, sprayed some PB Blaster on them about 5 minutes prior... Looks great too... Thanks again DAVE!
Nicholas
Old June 27th, 2004, 06:54 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I put mine on with a full tank--the tank is wedged in pretty good. I put a floor jack under the skid and lowered it slowly till it wedged and then all the way--put the new one in place, raised the jack and hammered on it till the holes were aligned. No biggie. I do have air tools, though. YOU CANNOT GET AIR TOOLS QUICK ENOUGH IF YOU DON'T HAVE THEM! TRUST ME! Bite the bullet, take the lumps, till your spouse "sorry", but get them! Best place? Pawn Shops.
Old July 11th, 2004, 03:38 PM
kiefffff's Avatar
kiefffff
Keith Rider
1994 Portofino ST: #217
Finally had a chance to try and attach the new skid plate. Got some questions. I have already sheared off two bolts. The others won't budge. Sprayed A LOT of WD-40 on the bolts already. Will the impact driver, wrench be my best bet to get these bolts off? What happens if all bolts are sheared off? Drill them out? Lose the sway bar or re-attach?
94 Defender
11 Toyota FJ
Old July 11th, 2004, 03:50 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
WD-40 is good as a lubricant but is really a Water Displacement lubricant. Try a super penetrate like Nut buster (I think its called) or other "Liquid Wrench" type products. Soak them good and then soak them again. I would assume that an impact would work best. I just had dealership lossen mine for me while the 90 was in for something else so I can swap my fuel skid when it gets here.
Chris von C
[/size]
Old July 11th, 2004, 10:24 PM
flippedrover
Tyler
'94 D-90
Ues a lot of PB blaster. I went through a can of it on mine. I guess you are stuck with drilling the sheared bolts out. I bought one of those bolt out kits and tried it on the one that I shered off. Didn't work unfortunatly but then again I mounted the skid without that one bolt.
Jimmy Buffett
Old July 19th, 2004, 02:23 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
Hey, I joined the club!
The sway bar bracket bolts and the forward 4 bolts for the pan have threads that are accessible, so I was able to douse them in Liquid Wrench on Saturday. Next day they came off pretty easily.
Couldn't get any oil on the thread for the back two, however. Was turning them with a 2-foot breaker bar, but man they were complaining about it. Broke one clear off. 'drilled a hole in it and put in a cheap screw extractor I got at Harbor Freight, and that broke off, too. 'hope the Chinese steel it's made of is as easy to drill through as the bolt!
I got the other most of the way out, but the hex head's rounded off now. 'doesn't help that one of the bars of the hitch is in the way, and prevents a straight shot with the socket extension. So I'm off to Sears today to pick up some of those sockets that bite into damaged hex heads. In the mean time, I tried soaking the bolt in more Liquid Wrench, although I don't think that's very effective when done from below.
Old July 19th, 2004, 03:26 PM
zed111's Avatar
zed111
Zed
1994/Defender 90
Dave,
Can I still use the rear sway bar and factory step & tow rear bumper with your skid plate?
Also, when will you have more in stock?
Old July 20th, 2004, 01:21 PM
kiefffff's Avatar
kiefffff
Keith Rider
Zed - The new skids only have the sway bar holes drilled, no threads in skid. The factory skid was threaded for the sway bar bolts. To re-attach the sway bar, had to use lock nuts with new bolts and lock washers. Works fine.
Tyler - I only attached 5 of the 6 skid bolts too. Tried the easy outs to remove broken factory bolt and broke the easy out!
Old July 21st, 2004, 12:02 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Zed,
Keith is correct,
The sway bar holes are there, you just need to use a bolt and nylock nut to hold it in place.
"Also, when will you have more in stock"
I have been having a hard time keeping them in stock, but I will start on more soon. Email me if you would like more info so we do not take the thread any further off topic
Old August 1st, 2004, 07:25 PM
chrisvonc's Avatar
chrisvonc
Chris von C
After breaking one of the bolts and spending about an hour working lube into another one so as not to break it, and then figuring out exactly how to strap up the gas tank once I was able to drop it a little, the skid plate is now on. My old one was a lot worse off than I though once it semi-cleaned it off.
Thanks Dave! Ready to drop my ass on the rocks again.
Chris von C
[/size]
Old August 2nd, 2004, 07:00 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
Yea, me too. Plus, the high-carbon steel on the EasyOut is impossible to drill through. This is what I did; maybe it can help others in the same situation: I got a small carbide cutter for my Dremel tool (looks like a miniature milling bit). It worked surprisingly well. With this, I was able to mill out the piece of the EasyOut that ended up in the bolt.
I didn't try the EasyOut route again. Instead I got a 5/16" aircraft drill bit ('needed the length because of the hitch tube that was in the way), and drilled out most of the bolt. What little was left of the bolt broke loose from the threads when I hit it with a hammer and a punch. 'cleaned up the threads with an M10 tap and was good to go. I use new stainless steel bolts all around.
Old August 3rd, 2004, 02:22 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
The Hardest Part Was..........?
Well I finally had time to put Dave's Bomber Skid Plate on.
It took me a whole hour!
I was hoping that it would take longer, because I really like wrenching on the ol' 90.
I tried to make it last longer. I inflated 2 basketballs for my kids, took their bikes down from the hooks on the ceiling, and made a run to ACE for some new bolts and nuts for my sway bar.
The best part was teaching my 6 year old to use the floor jack so I could hold the skid plate in position while he raised it up.
--Benjamin Franklin
Old August 3rd, 2004, 02:51 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
"It took me a whole hour!"
Show off
fuel
Fuel tank skid plate GeoParth Defender Technical Discussions 53 June 25th, 2006 03:21 PM
Fuel Tank Skid plate Gore Ranger For Sale - Parts 0 March 14th, 2006 01:22 PM
Fuel Tank Skid Plate sgarrett For Sale - Parts 2 April 10th, 2005 04:09 PM
fuel tank skid plate, bumper, & rotors tonymotosource For Sale - Parts 11 January 26th, 2004 01:20 PM
