Fuel sender plug/fitting - Defender Source
Old March 31st, 2016, 02:56 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
I'm hoping this is a rather straightforward question. After upgrading my 300tdi to a plastic tank and appropriate sender I need to find the appropriate female plug to wire into my loom that plugs into the sender.
Does anyone know if this style plug is used on any North American models, or what it's actually called so I can try and order one somewhere?
Thanks in advance
Will
Old March 31st, 2016, 03:06 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Looks same as '96 4.0 D1.
https://www.outdoorwire.com/4x4/rove...ll/newpump.jpg
Check the wiring diagrams to confirm they match. If not, think your best option would be to get a 6" pigtail from a breakers in the UK.
Old March 31st, 2016, 03:10 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Originally Posted by Landy_Andy View Post
Looking at that I think your best option would be to get a 6" pigtail from a breakers in the UK, unless it's used on the D1/D2 ?
I was kind of thinking there might be a remote possibility a D1/D2 might be the same... maybe someone will know.
If not any suggestions of a non-shady breaker who would be willing to ship such a small item to Canada?
Old March 31st, 2016, 05:19 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Will,
I think its this: 174257-2 | TE Connectivity Econoseal J Mk II+ Series, 4 Way 2 Row Plug Housing, Plug Housing | TE Connectivity
The connections used on later vehicles are typically AMP econoseal or Tyco plugs and sockets
USA: TE Connectivity - 174257-2 - 4 way Econoseal J Mk II plug housing - Allied Electronics
regards all
Gren
Old March 31st, 2016, 05:24 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Originally Posted by Gren_T View Post
Hi Will,
regards all
Gren
That sure looks like it could be it. Thanks very much for this promising lead
Old April 6th, 2016, 10:49 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Got the Econoseal in the mail today and it fits! Thank you for pointing me in the right direction Gren.
Old April 6th, 2016, 12:43 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
So what are you doing to get the correct wire leads & fittings for the Econoseal socket?
My concern is for if/when the leads could possibly rust out & need replacing.
Old April 6th, 2016, 12:45 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
That remains to be seen. I'll post back up once I've figured something out.
Old April 6th, 2016, 01:04 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Digi-key stock TE Connectivity parts :
Female pins for 16-20g wire :
171662-1 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey
Silicon seals:
900324-4 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey
4 way housing:
174257-2 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey
Hope that helps.... and you'll not get stung import duty
Old April 6th, 2016, 01:06 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Well rookie mistake not getting those, guess I'm ordering from them again. At least shipping is cheap and fast. Thanks for the links!
Old April 6th, 2016, 01:29 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Your not the only one that's done that.... I mis-ordered the terminals for my fuse box from VWP in the UK.... cost me twice in shipping.... Doh
fuel
Fitting VDO Speed Sender ajh Defender Technical Discussions 75 January 18th, 2017 05:44 PM
Freeze plug/exspansion plug replacement WildBoar Defender Technical Discussions 5 March 27th, 2015 03:16 PM
300tdi Temp Sender Plug TDI Guy Defender Technical Discussions 3 April 19th, 2009 08:02 PM
fuel pump sender Abrooks Defender Technical Discussions 0 August 16th, 2005 04:29 PM
Fuel Pump / Sender 95 D-90 Nigel Buchan For Sale - Parts 1 November 20th, 2003 11:03 PM
