Fuel sender mounting.... - Defender Source
Old June 10th, 2006, 10:23 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Anybody have any photos that can show me how the fuel level sending unit mounts to the tank on a NAS D-90? I hate brainstorming, but not having all the info I need.
-Hans
My oil line fix
My 100k stopped odometer fix
Old June 10th, 2006, 11:04 PM
mattdh's Avatar
mattdh
Matt Hurst
hans-this is a pic off the rover connection web site
probably does not help.may want to go to the site and check it out
a wire arm with a rubber float on one end, the other end attaches to a circut board type thing as the arm float up and down this metal tab rubbes up and down on this board type thing???????help-no help?????
Old June 11th, 2006, 09:00 AM
artm
Arthur Maravelis
97 SW
This is for a 97 - should be the same.
Old June 11th, 2006, 10:27 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Hope this helps -- it's a '94 with ECRs seriously nice stainless setup. I can easily take more if necessary.
Tony
Old June 11th, 2006, 11:36 AM
Hans's Avatar
Hans
Hans Haase
Thats what I was afraid of. The sender is integrated into the fuel pump system. Makes it harder to change it for gauge compatibility.
-Hans
My oil line fix
Old June 11th, 2006, 11:55 AM
For guage compatibility you need to determine the ohm range - I think a search here will turn up the ohm range of the stock unit - I think VDO gives you an option of ohm ranges. I would think that someone with electronics skill could devise a resistor set-up to make things work out? I dont know exactly what is required, but perhaps you can get around swapping out the sender?
Old June 11th, 2006, 05:16 PM
Hans's Avatar
Hans
Hans Haase
There are some options available. Some Autometer gauges are fully programmable for any sender, which is what I will most likely be using. Some higher end companies that you can order direct from will also calibrate the gauges custom for what we need. But just like ALL the other gauges for us, it's an annoying process of custom made parts.
Of course, you could always cut another hole in the top of the tank and put another sender in it..... but then we are getting complicated already.
-Hans
My oil line fix
fuel, mount
fuel pump sender Abrooks Defender Technical Discussions 0 August 16th, 2005 04:29 PM
Fuel Pump / Sender 95 D-90 Nigel Buchan For Sale - Parts 1 November 20th, 2003 11:03 PM
