Fuel return line popped off - Defender Source
Old December 20th, 2014, 10:44 AM
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
so... Sitting at a stop light and i hear a little pop, and the engine seems to pick up some rpms maybe... Run smoother.
Smell diesel, pul over and my return line has popped off the end of the rail.
This can obviously be a clogged line, but if so, it seems transient.
Could also be a failed or clogged injector right? My diesel knowledge is neophyte but seems like if the pressure don't go into the cylinder it goes into that line. PotentiAlly over pressurizing it momentairly.
No apparent change in running currently, hose isnt popping off again.
Old December 20th, 2014, 10:49 AM
First off remain calm.
Next stop off at a Mercedes dealer and grab a foot of return hose from them and swap yours out. I'll bet it just came off because it's old and tired.
If they don't have it try NAPA or any other car parts store.
Start with that and then we can move on if you still have an issue.
Old December 20th, 2014, 11:03 AM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
I picked up a few feet of Gates branded fuel hose at o'rileys. did the trick.
Old December 20th, 2014, 11:57 AM
DefenderMd's Avatar
DefenderMd
Ben
So yea, it is popping off regularly now.
So y'alls thinkin its up before the fuel filter then eh? Cuz it'd take more than a few feet to go all the way to the tank.
I'll yank it and find some similar hose. I hope i dont have to drop the tank... It is full full...
Old December 20th, 2014, 12:33 PM
Most people have issues with the fuel return lines that attach to the injector manifold. If it is the tank return hose cut off the last 1/2" and reattach it or you can put a jubilee clamp to hold it on. Again it is probably stretched out and old.
Old December 20th, 2014, 03:48 PM
DefenderMd's Avatar
DefenderMd
Ben
aH... WELL... IT seems I had a bit of a misunderstanding on how this was put together.
to start with I undid the banjo bolt on top of the filter housing (where the fuel rail return is) and rather than a normal banjo bolt with a big ol hole in it. It had what was more like a carburetor jet sized hole. Like... from a lawnmower.
I could not see light through it and could pass little air. I ran a #20 K-file through it and bam.. no problem.
Easier than expected. I figured it had to be some huge build up or something.. just a grain of sand/rust or 2.
fuel
Injector return line leak no more BlackField Defender Technical Discussions 0 August 24th, 2013 11:48 PM
200Tdi injection fuel return line banjo bolt Apocalypse Vehicle Defender Technical Discussions 8 August 20th, 2013 11:13 AM
Front brake line - why hard line & flex line? jefhuf Defender Technical Discussions 5 January 13th, 2012 09:03 AM
NAS Fuel Return Line TDI Guy Defender Technical Discussions 4 July 10th, 2010 06:52 AM
300 tdi fuel return lines leaking discotdi Defender Technical Discussions 1 June 30th, 2008 10:49 PM
