fuel rail and injectors - Defender Source
Old June 11th, 2010, 12:00 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
I am getting ready to pull the fuel rail. I looked through the procedure in the workshop manual and was wondering if there is anything to watch out for? The manual makes it sound semi-complex and was wondering it is really that hard. I am pretty handy.
thanks,
Bill
Old June 11th, 2010, 01:30 PM
PTSchram
P. T. Schram
Down to only six!
The hardest part will be getting the lower plenum off the manifold.
Occasionally, they are tremendously tightly stuck together.
Wrench to wheel, wheel to wrench
Old June 11th, 2010, 04:02 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Everything is straight forward--nothing in that process is tricky. I agree with the stuck plenum--I used a prybar and while applying medium pressure, used a dead blow hammer to create a little shock till it gave way, but you have to be very careful not to break the casting.
Old June 15th, 2010, 04:31 PM
kolvedic's Avatar
kolvedic
Bill Lewis
Thanks! I did the work this weekend in a few hours. Now I am just waiting for the other parts to finish up the job.
bill
Bill
fuel
starts fine unless ignition switch left on.... Davis Defender Technical Discussions 7 June 10th, 2010 01:14 AM
One bank flooding out Defenderbuser Defender Technical Discussions 5 June 16th, 2009 07:48 PM
4.0 fuel injectors crobinson Defender Technical Discussions 3 January 17th, 2009 09:08 PM
Fault Code P0183 proulx70 Defender Technical Discussions 8 November 17th, 2008 04:05 PM
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
