fuel pump wiring bypass - Defender Source
Old October 17th, 2012, 11:25 PM
ember
ember bane
I'm not getting power to my '97 D-90 fuel pump, Would it hurt the pump/fuel system if I run a power wire from the ignition switch? I know that when the key is turned to position 2 that the fuel pump is supposed to pump a few seconds and then turn off, Just wondering if the pump doesn't cut off it it would hurt anything.
Old October 17th, 2012, 11:34 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Why not figure out why there's no power at the harness plug instead?
Old October 17th, 2012, 11:48 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Start at the fuel pump and work you way forward on the harness. Probably a bad ground.
Old October 18th, 2012, 01:10 AM
ember
ember bane
thanks for the advise guys, unfortunately I can't seem to be able to find a wiring schematic for the 1997 model year. I have a shop manual for the earlier years, but can't find one for this one. I have power going as far as the inertia switch, but then the wire goes through the firewall and I have no idea where it goes next. There is no power at the fuel pump relay or going to the pump.
Old October 18th, 2012, 07:57 AM
You've ruled out ignition switch problems? ipgregory seems to post the wiring info for 1997 every few weeks if you try some search terms. I also post this every few weeks. Save it as a favorite on your computer and phone.
http://lhsw.com/d90/
Old October 18th, 2012, 08:16 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
A lot of people have had problems with the connections and the grounds. If those checked out then the switch and the relay are the next step. I am pretty sure that you have two power leads going into the relay, one hot and one switched. Do you have power to both of these?
Land Rover 110
Old October 18th, 2012, 08:21 AM
Have you replaced the relay yet?
fuel, wiring
Fuel Pump, Switch, Relay, or Wiring? bbandit Defender Technical Discussions 19 July 10th, 2005 12:08 PM
