Fuel Pump Wiring 95 D-90 - Defender Source
Old January 28th, 2013, 07:28 PM
jhhorse
joe heins
1995 defender 90
Hi,
Anyone know the best spot to hotwire fuel pump on a 95 D-90 directly to the battery to check pump operation, WITHOUT dropping fuel tank? (and which color wire) It looks to me like I have a wrapped wire bundle coming from the top of the tank and taking a hard turn to the left (looking back), and it looks like it joins another wire bundle going forward.
Joe
Old January 28th, 2013, 07:43 PM
Gecko
Stefano Watson
94 D90
Couple of ways to do this from memory. The schematic is not the same on a 94/95 as it is for a 97.
1) There is a connector in the rear passenger wheel well. Disconnect that harness and add power to the white wire (it may have a tracer on it (green or red)) and ground it to any one of the black wires or the frame.
2) Pull out your fuel relay and place a jumper from 30 to 87. There are two 87 slots, use the one on the edge. I think the other one powers the O2 sensors.
90, 95, d-90, fuel, wiring
fuel pump wiring bypass ember Defender Technical Discussions 6 October 18th, 2012 08:21 AM
No power to fuse for Fuel pump on 94 D90. B-Kerr Defender Technical Discussions 10 October 23rd, 2008 06:43 PM
external fuel pump snuffer Defender Technical Discussions 8 May 9th, 2005 04:14 PM
Fuel Pump Issue bjenk Defender Technical Discussions 12 December 5th, 2004 09:00 PM
Fuel Pump / Sender 95 D-90 Nigel Buchan For Sale - Parts 1 November 20th, 2003 11:03 PM
