Fuel pump starts, then shuts down - Page 2 - Defender Source
Old September 28th, 2015, 12:11 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Originally Posted by EnduroPro View Post
Lucas is a wise man.
no Lucas is an asshole
Jimmy Buffett
Old September 28th, 2015, 12:33 PM
Originally Posted by o2batsea View Post
That white with black tracer may not look like much but it is absolutely critical to the operation of the engine. Be sure it is connected securely. Without it, nothing worky. It is not uncommon for the wire to fatigue and break right at the spade terminal. Seen more than one hanging on by literally one strand.
If it's not connected, the engine will not catch because the ECU still thinks it's not running. You will still hear the fuel pump go thru the prime cycle cz that is not tied to the engine firing and running. Once the ecu receives coil pulses for a certain period, then it starts the fuel pump.
This is a likely cause. Chicklet is related as well as I believe it is on that line. Search for the word chicklet and you should see the threads.
A final issue which is very rare to check is the pick up in distributor which has something do to with the ECU (according to someone who should know -- don't take my word for it).
Old September 30th, 2015, 05:51 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Woohoo! She's running!!!
http://youtu.be/NW6oZn9IYaE
It was the resistor by the air intake on the firewall. Wow what an adventure that was. Thanks everyone for all the great guidance. This really is an awesome crew of people.
Old September 30th, 2015, 07:13 PM
Woohoo! She's running!!! http://youtu.be/NW6oZn9IYaE It was the resistor by the air intake on the firewall. Wow what an adventure that was. Thanks everyone for all the great guidance. This really is an awesome crew of people.
Wait hadn't we said to look at that like 10 threads ago? congrats.
Old September 30th, 2015, 07:15 PM
Just curious did this start before or after you installed that Mallory distributor? If after, how long after?
Old September 30th, 2015, 08:42 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Sure did! My mechanic buddy had a little case of tunnel vision. Thanks again!!!
------ Follow up post added September 30th, 2015 08:49 PM ------
Long story but here are the highlights:
Had another friend hear my woes of the defender. He suggested a better distributor as he interpreted my issues as electrical. So we swapped out the original distributor for the Mallory. The problem was that the Mallory came with an undrilled hole for pinning the gear. Realizing that after we already pulled the original. So we had to shelf that project for the day....that day turned into 4 years as I got focused on Ironman triathlon, then my wife when and had twin girls. So free time and $$ were focused elsewhere. My new mechanic buddy owed me an enormous favor and promised to make my Defender run, whatever it took. He had quite the project as he had to unravel the works of several mechanics before him.
fuel, start
1994 land rover defender shuts off randomly marsik Defender Technical Discussions 50 November 11th, 2015 07:03 AM
D90 starts then stops Hinckley423 Defender Technical Discussions 3 September 22nd, 2014 02:58 PM
Clutch pedal sticks to floor, then starts popping up as the truck gets warmer. Quimbola Defender Technical Discussions 7 December 30th, 2008 04:43 PM
D90 Starts Slowly. Any ideas? cdnpaul Defender Technical Discussions 7 October 31st, 2003 11:27 PM
