Fuel pump running while defender is off - Defender Source
Old June 16th, 2009, 01:49 PM
ollieskins's Avatar
ollieskins
Wade Garrett
1994 defender 90
Hi all, I have posted this before, but never got an answer. I try to turn my key a little bit so I can listen to the radio, but when I do this the fuel pump runs (even though the truck is off). Any ideas? I have already pulled out the relays, but it still runs.
Old June 16th, 2009, 03:11 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
If you pulled the relay and it still runs then something is wrong- someone may have straight wired the pump to pos. 1 on the ignition.
Old June 17th, 2009, 01:05 PM
ollieskins's Avatar
ollieskins
Wade Garrett
1994 defender 90
hmmm. Do you think that will be an expensive fix for a mechanic?
Old June 17th, 2009, 01:17 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Why not wire your radio to an "always hot" source? Then the radio will be on and you'll turn it off with the radio switch.
Dennis
fuel
Fuel Pump running PSI and deadhead PSI? RedRhinoProducts Defender Technical Discussions 0 February 27th, 2005 02:35 PM
