Fuel pump replacement struggles??!! - Defender Source
Old September 12th, 2014, 09:50 PM
RickM
Rick Mabus
95 D-90 ST
Hey guys. I'm stumped and I'm pretty sure this is all over the forum but my search yielded nothing. Anyway I am working on dropping my tank. The skid plate is gone. The filler hose, and the other hose to the top of the pump are disconnected. I'm having a big fit however disconnecting the vent piping from the box attached to the passenger side wheel well. The green cap looks like it should come loose somehow but I'm not sure how. Any advice would be massively appreciated. Pics below.
http://www.defendersource.com/forum/...1&d=1410572947
Old September 13th, 2014, 09:41 AM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Paper clip.
Two slots, bend paper clip to fit in both slots, pull tube out closest to you.
You do not need to apply lots of pressure.
Hope this helps.
Weldon
Old September 13th, 2014, 10:35 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
It's just a fancy push fitting. The green cap is just a dust cover over the collet. If you can't release it by pushing on the collet through the slots in the green cap, then use a small screwdriver to pry off the green cap and push on the collet to release the plastic line. A little silicone spray may help if things are stuck.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old September 13th, 2014, 11:19 PM
RickM
Rick Mabus
95 D-90 ST
Thanks guys. I got it. I think it was just really gunked up and didn't want to let go.
Old September 24th, 2014, 10:43 PM
RickM
Rick Mabus
95 D-90 ST
Well. Now I'm stumped. Did all this work and now my fuel pump is either a bad unit or it's not getting power for some odd reason. Now my truck is stuck at my office. Any ideas on where to start chasing this electrical gremlin?
Old September 24th, 2014, 10:54 PM
Is there power at the pump with the key in the run position?
Fuse?
Relay?
That's where I would start.
Old September 25th, 2014, 10:15 AM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
When key is in the first position, do you hear the pump/relay kick on?
Weldon
Old September 25th, 2014, 10:31 AM
the rover shop
shayne young
I can send you a couple of pics of the location of the fuses and relays and wiring diagram if you need it..
Old September 25th, 2014, 06:41 PM
Is it an aftermarket pump?
Old September 25th, 2014, 10:08 PM
RickM
Rick Mabus
95 D-90 ST
It's definitely an aftermarket pump. I also did change the relays, fuse, filter, and pump when I did the whole project. I thought about this long and hard, and I decided that I'm not comfortable with electrical gremlins as a DIY'er. Burning my truck to the ground is just not in my plans. I had the truck towed to NTX British to let Alan do his magic.
Old September 25th, 2014, 10:18 PM
Let us know what he finds.
Old September 30th, 2014, 10:38 AM
RickM
Rick Mabus
95 D-90 ST
The verdict is in. Sort of. Apparently it was a bad fuel pump that I had purchased and installed. Allan at NTX British bypassed the current tank and fuel pump somehow and the truck started right up.
Old September 30th, 2014, 10:46 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Glad you figured it out. Does anyone know what a replacement for that green capped collet fuel vent tube fitting is? Mine always gives me fits. When I dropped the tank this weekend to fix the fuel level sending unit, the green cap disintegrated and the collet never released---I man handled the tube out. Still working, but I want to swap it out (probably have to cut the hose and do some magic) and wondered if anyone knew what a replacement part for that bit may be (or may be called).
Thanks!
Old September 30th, 2014, 07:16 PM
I've had bad luck with aftermarket fuel pumps in Land Rovers, I would definitely go Genuine.
ac, fuel
Fuel Pump Replacement Time Already? Help Me Confirm. rijosho Defender Technical Discussions 39 September 10th, 2014 12:33 PM
Fuel Pump replacement on a 94 D90 101stAirborne Defender Technical Discussions 11 February 6th, 2014 08:56 AM
TD5 Fuel Pump/ pump tomaco1 For Sale - Parts 7 September 20th, 2011 09:13 PM
feed 200tdi lift pump from Facet fuel pump ? kjva Defender Technical Discussions 1 September 7th, 2011 01:55 AM
replacement fuel pump for '97 D-90 Cirbo Defender Technical Discussions 3 April 7th, 2007 03:19 PM
