Fuel pump pulley adjustment - Defender Source
Old April 3rd, 2016, 09:34 PM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
Hi guys,
When replacing timing belt, how do you know where to set the fuel pump pulley back exactly as it has a little bit of slack about 20 degree or so even with the pin inserted? I am talking about the pulley itself when it is loosened from the fuel pump spindle.
I know you are supposed mark its position using some sort of marker prior to disassembly but I am assuming it is likely off.
I purchased this engine from someone but I don't trust anything on this engine and I am assuming what the seller claimed to have done actually is either done wrong or not done, hence the overhauling.
Michael
Old April 3rd, 2016, 09:38 PM
The pin locates the pump. The pulley is wherever. Choose a cog that puts it in the middle of the available travel with the belt tensioned. The bolts are only to be tightened with the belt tensioned.
Old April 4th, 2016, 01:35 AM
DailyDrivenDefende
Michael
So the small rotation play that can be much as a tooth or two doesn't matter as long as the pin is holding the pump where it is and you center the gear in the middle of that free play?
Thanks John.
fuel, pulley
Water pump pulley wearing my coolant hose. 300 tdi sundogcwolfe Defender Technical Discussions 11 February 16th, 2012 12:29 PM
200tdi PS pump , Rad, and Crank pulley tomaco1 Wanted 3 April 17th, 2011 04:06 PM
Looking for oil pump / front cover & crankshaft pulley HeloBubba Wanted 1 February 12th, 2011 02:20 PM
3.9 water pump pulley ZACHASS Wanted 1 December 2nd, 2008 09:25 AM
Vendor for Power Steering Pump Pulley wheel ? norros Defender Technical Discussions 0 January 19th, 2005 04:12 PM
