Fuel pump problems 3.0 - Page 2 - Defender Source
Old July 12th, 2015, 12:00 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Can you post the page of the manual that shows the fuel pump electrical circuit? What part of the circuit have you checked so far?
You want to troubleshoot when it is working (and write down what you see/confirm it matches the circuit. Obviously, the best time to troubleshoot is when the truck does not start (because you can see what's different from expected behavior:measurements.
To troubleshoot electrical issue a voltmeter is best (you did not say how you are doing your troubleshooting. A wire + bulb can also work in many cases ).
MonLand
1995 D90 NAS
1996 Discovery NAS
TD5 Fuel Pump/ pump tomaco1 For Sale - Parts 7 September 20th, 2011 09:13 PM
feed 200tdi lift pump from Facet fuel pump ? kjva Defender Technical Discussions 1 September 7th, 2011 01:55 AM
starting problems and correct voltage to fuel pump cdb Defender Technical Discussions 1 July 28th, 2009 11:31 AM
Electrical Problems Galore- Coil, MAF Sensor, Wipers, Fuel Pump, Short Heath Defender Technical Discussions 10 August 28th, 2008 05:52 PM
Fuel pump and fuel gauge relationship question - troubleshoting... arbik Defender Technical Discussions 1 September 19th, 2006 02:31 PM
