Fuel pump noise - Defender Source
Old March 3rd, 2004, 03:11 PM
PT94D90's Avatar
PT94D90
Phil
Currently Defenderless
Fuel pump noise
My fuel pump is making a loud, high-pitch, whine noise. Is this something I should be worried about, or a common D90 quirk?
Old March 3rd, 2004, 03:25 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
I believe that high picth whining is normal. When you turn the key one position it should activate the fuel pump and as a result it primes the system.
DJ
Old March 3rd, 2004, 03:26 PM
I think shes on her way out.
Old March 3rd, 2004, 05:48 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
If it is the same noise I have you may last a while. Every so often I will hear a high pitched whine coming from the back of the vehicle after I turn off the ignition and it will last for a few minutes and then go away. I don't know if it is coming from the speakers or what. But for what it is worth it has been making the nosie for about 4 years now and so far so good.
fuel
Fuel Pump noise Campbell Defender Technical Discussions 3 December 9th, 2004 10:08 AM
