Fuel pump issues... - Defender Source
Old December 22nd, 2012, 06:53 AM
Fred Lobster's Avatar
Fred Lobster
Pete Gerbine, III
1993 110 (#451)
Fuel pump issues...
Looks like I'm about to have to purchase my 3rd fuel pump...in as many months! Has anyone else dealt with or had issues with the Pro-Line fuel pumps? As many times as I've had to replace the fuel pump, I'm thinking it may be worth relocating the rear cross brace and make a hatch in the floor for easier access...this is getting old!
Old December 22nd, 2012, 09:37 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Assuming a V8 and it's the pump failing, you should be able to find a Delco pump unit to replace the pump with.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old December 22nd, 2012, 10:00 AM
If it is the actual pump part, you remove the cartridge and replace it with an $80 generic from NAPA.
Old December 22nd, 2012, 10:20 AM
Fred Lobster
Pete Gerbine, III
1993 110 (#451)
It is a V8. I am getting power to the plug...but the pump does not kick on. Is the Delco pump a direct replacement or is there a PN that I need?...sorry, the search feature is not working on my phone if it's already been covered... Same question for the cartridge... and can you tell me how I can determine if it is the actual pump part?
Is an inline fuel pump a ridiculous solution?...again sorry if it's been covered already...not able to access a computer right now to utilize the search....
Old December 22nd, 2012, 10:46 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
i have use many pro line pumps and never had a issue,I would have to think you have something wrong with the harness more than likely a bad ground .. i would look into the fuel pump circuit before throwing more pumps at it ....
No Mall crawler here
Old December 22nd, 2012, 11:43 AM
Fred Lobster
Pete Gerbine, III
1993 110 (#451)
Would I be able to test that by hooking up 12 volts directly to the fuel pump plug, with a solid ground? Is it ok to bypass the fuses and relays to see if the pump kicks on?
Old December 22nd, 2012, 12:07 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Yes but if the pump might have failed .due to the poor ground or erratic 12v feed....the 2 grounds from the pump are joined in the harness which is then grounded to the passanger side of the t box ...you can cut those wires back from the connector and run a new ground lug also have to make sure your getting a clean 12v from the fuel pump relay and do a wiggle test to the harness i could almost bet theres some corrosion causing these problems....always start with basics when diag ...power / ground ...hope this helps a bit
fuel
YANST (Yet Another No Start Thread) - fuel pump circuit issues cgalpin Defender Technical Discussions 25 August 2nd, 2009 11:23 PM
